restorer-john
I know Technics had a fairly extensive range of cartridges.
Here's the 1983/4 range...
6 Boron piped cantilevers, a titantium cantilever etc.
And here's their Crosley killer from the same year
Did I miss this, or did schiit happen?Not a double review yet, but I'll have the second part up this weekend.
Any progress?
I can't speak for the FR-64, but the FR-24 Mk2 is a hell of an arm and plays well with a wide array of carts.Today, low mass for the sake of low mass, or even low tracking forces, are something few people talk about, or are really interested in. Back in the '60s and '70s it was a big thing. I remember how folks were incredulous when Mr. Ikeda said you needed his heavy FR-64 arm and cartridges. Other Japanese 'high enders' were also touting the benefits of old gear like the Grace/Gray oil damped arm and DL-102. Mr. Sakuma of Direct Heating taped coins to the arm in order to give it enough 'weight' for his mono records. LOL
Member @BDWoody was kind enough to send two phono preamps my way for testing. One was the Pro-Ject Phono Box DS+, the other was an almost-antique (vintage 1983) Straight Wire Audio (SWA) Phono Preamp. The results and comparison were interesting...
I do have a couple of concerns here: first, I don't like seeing the wires from the power supply connector (the red and black twisted pair) running across the length of the board near sensitive circuitry. Second, the RCA connectors are rather cheep'n'cheesy, with input and output grounds connected directly together.
Ditto on schematics I have analyzed. Also, the wall wart is not grounded, and provides 18VAC, where the incoming supply does provide gnd on board which (I think) is tied to the input and output grounds.In the spirit of there being no such thing as a stupid question, what is the alternative to the grounds being connected? The phono preamps I've examined all seem to have the RCA grounds tied to the same ground plane/bus/whatever on the circuit board?
There's a few different ways of doing grounding. Inputs can float, for example or be balanced. For a common ground, the order of connection can run from input to output, with chassis ground being connected at the input, sometimes through a resistor (see, e.g., Morgan Jones's "Valve Amplifiers" for a discussion of this). The latter is how single-ended phono preamps ideally should be constructed.In the spirit of there being no such thing as a stupid question, what is the alternative to the grounds being connected? The phono preamps I've examined all seem to have the RCA grounds tied to the same ground plane/bus/whatever on the circuit board?
The problem is that just looking at a schematic, all ground points are equipotential, all ground runs have zero resistance. So it shouldn't matter. In the real world, they're not, so layout and the order of grounds becomes important at these low signal levels.Thank you, the various approaches and how similar they seem in theory and yet how much they differ in real-world performance has been surprising to me.
OTOH, my lack of understanding may explain what I perceive as similarity, those that understand better may not agree that these are very similar.
