Don, I understand full-well that you know more about this stuff than I do in the fingernail on my pinky. You understand 32-bit float (something few here seem to understand). If I can give you the short version. I know your time is limited.
I know what I know, mostly, and sometimes realize what I don't know. I have no idea your knowledge level; the post I first saw was the one where you said quantization did not relate to an SNR number, and that is incorrect. Quantization noise sets a lower bound on noise and thus an upper bound on SNR. I may have misunderstood your context since I did not read all the preceding posts. You may have really big pinkies...
My background is primarily in transistor-level (IC) high-speed data converter design for radar, communication, digital imaging, electronic warfare, and so forth with a recent diversion into serial signal testing (the analog portion of SerDes embedding in large SOC's). I thought you were questioning my credentials and responded accordingly, should not have done that, sorry. I rarely bother as it tends to lead to a credential-pissing contest, a dismissal ("oh, you're an engineer, no wonder you don't understand what it sounds like"), or just glossed over as irrelevant.
The following comments are more general and not necessarily audio-related (as you will see).
Rode has been marketing their "Wireless Pro" device as eliminating the need of an analog gain setting to reduce clipping. They want to sell stuff. I get it. But I feel that crosses the line in making a scientific claim that the use of 32-bit float memory allows one to get an unclipped digitization of microphone data. Zoom, SoundDevices and TASCAM are all making that claim, to greater or lesser extents. Most likely, the manufactures of these ADC/DSP chips have integrated a digital signal processing function to clean up the digitized audio in a way that reduces the perceived sound of clipping. I don't dispute any of that. I would be fine as marketing those new chips as having a "Proprietary Anti-Clipping Technology" Those manufacturers can make up any words they want. I wasn't born yesterday
But no, you can't take a word I (we?) use, "32 bit float" and say it can do something it cannot (at the core ADC conversion point).
I did not read the Rode article and have no real desire -- the gulf between engineering and marketing is one we have dealt with "forever" and are unlikely to resolve here. Does not mean we should give up the good fight.
I skimmed but did not read in detail all the posts to this point (been busy with things more important to me than ASR, so that's on me). FP alone does not absolve or eliminate clipping, nor will any real-world system completely eliminate it, but it does allow (with appropriate ADC and system architecture) much greater dynamic range than a single ADC can provide. FP can reduce memory requirements but does not itself relate to clipping (or not) of the data conversion process. Using gain ranging before the ADC (or after a DAC) with FP words can provide higher dynamic range, but is a bear to implement IME.
Given a 32-bit ADC with XX Hz bandwidth is impractical, and a desire to capture a wide dynamic range, then using a multiplying ADC, floating-point ADC, or several ADCs with gain-ranged (or ranging) front ends to achieve the same dynamic range is one solution to the problem. For gain ranging, there are several choices, including multiple ADCs with fixed gains (choose the one for the signal level of interest), dynamically-switched amplifiers (gain stages) before the ADC, amplifiers with dynamically varying gain, and so forth. Any of those can yield much greater dynamic range than a stand-alone ADC, though achieving the 194 dB range (based upon SNR) of an ideal 32-bit ADC seems a very challenging goal. I have read about a few systems approaching that, but bandwidths were very low. But for context, I did help design a radar system with 160+ dB dynamic range, that used multiple gain stages, filters, and ADCs along the way. Resolution (again, not the same as precision) ranged from 6 to 11 bits over about 100 MHz to >1 GHz bandwidth. Processing improved the SNR (digital signal processing is relevant to me because the ADC's bits go somewhere, ultimately into a computer system, to be useful). Fixed and floating-point was used at various points for memory efficiency, which related to power, important in flight hardware (air and space).
The biggest objection to gain ranging was the "small signal and large signal in the same capture bandwidth" when you really do need all the resolution. There are myriads of examples of that, like nearby transmitters in the same band you are trying to detect far-away transmitters (finding a signal a channel away from the local radio station), pulling small objects from a high-intensity and/or reflective background ("dingy on the ocean"), etc.
What responsibility do you or I have in protecting the technical meaning of "32-bit float"? The reason I make slip ups (and you made one, sorry, with 32-bit float) is that all this (I want to curse) marketing BS is distorting our ability to communicate in a precise way. Sorry I'm angry about it. It may look like I'm trying to prove some arcane technical point but my interest in much deeper and broader. Sadly, few seem to get it. If I can't come on an audio forum and say, "Rode says they prevent ADC clipping by using 32-bit float) and get a, "yeah, what can you do? The world is seriously falling apart"
reply, what does that suggest about other technical areas of society? Vaccines? Global warming?
I'm recently retired, so none?
I am not sure what slip-up I made with 32-bit float, but that is not and never was my day job; I am (was) an analog engineer playing in a mixed-signal world.
As for Rode, given the amount of marketing fluff I have read over the years, I would post a comment to them and perhaps various other places so people interested in understanding the issue would have someplace to go. I have no interest in making a legal challenge, just not worth the effort, and of course they count on that, but I also know many engineers who cringe at how marketing brochures counter real engineering and physics. Some of us have been able to get things changed, but it generally happens when either internal engineering makes enough of stink and presents a coherent case to upper management, or the marketing is enough that a major customer pushes back.
This is not the place to discuss vaccines, global warming, and such. Even if we could without it devolving into politics.
Let's say I knew for certain that the mRNA vaccines gave 6-year-olds chronic life-long heart disease with no difference in a death outcome, how easy would that be to prove to others? If I can't educate people about the misuse of "32-bit float", something trivial as can be, because people are EMOTIONALLY afraid to recognize an error in their communication, what hope something as frightening as heart disease in children?
I can only speak to engineering. There are numerous ethics committees and such, and signing up to be a member of the IEEE (for example) you agree to abide by their ethical guidelines, but I have no control over what Rode's marketing team does, or much of anything else. I can state my experience and analyses on places like ASR for audio and related things.
Communication is hard, and if you are hit upon or hit back, emotions are generally at play as we are all human (unless you are a chatbot, blah). When belief is attacked my first response is to attack back, maybe you are different? The trick (for me, again not always successfully) is to count ten, move past that, and respond rationally, something I do not claim to always (if ever) do. Heinlein: "Man is not a rational animal, he is a rationalizing one."
Words matter to me. Truth matters. At the age of 62 I feel stupid saying that. But I have nothing else better to do haha
Thanks for your time.
I am not sure where I lied in my responses; truthfulness has been beat into me from a young age and I try very hard to never lie, certainly not intentionally. I am roughly your age FWIW, but as grandmother said long ago, usually about grandfather, "Age does not necessarily bring wisdom; sometimes it just turns young fools into old fools." My saying for decades has been "Experience comes from making lots of mistakes, and wisdom is learning from them." So far, I've lots of experience...
