oh sorry I was quoting part of his post - did not think about it . that was already deletedMaybe so. How do you propose that we are able to prove or disprove this? Complicating matters you did not provide a username in your quote.
That would explain why I could not find the quote. Thanks…oh sorry I was quoting part of his post - did not think about it . that was already deleted
What is the composition of the apartment walls/ceiling/floor - drywall? Concrete? Something else? Because you mentioned neighbors all around.
I'd stop at 3500€. Maybe upgrade in a year or so if really necessary but that's the max for initial investment.$3-3500€ can buy a lot; will you stop there? How much more might you (or could/would you) possibly decide to spend in the future? Are you an upgrade-bug sorta person?
I've selected the EverSolo DAC Z6 actually because of the physical button to adjust the volume and because it has been positively reviewedWhy buy an MQA-capable DAC if your preferred file format is FLAC?
It is not easy for me to listen plenty of speakers. And I won't remember what I liked, or why I liked them. Listen to many speaker will likely confusing me more than helping me. I however have auditioned MA Silver 200 7G that I liked, Q Acoustics 3050i a bit less, and focal aria (926?) that I liked too.Are you somewhere you can go listen to a handful of different models in person?
Probably sitting in the sofa for "active" listening or just walking around in the living room for passive listening.How do you plan to listen to music
I'd say average+ volumeHow loud on average do you listen?
The room won't changeHow flexible is your room layout to achieve that (some help from DSP can be had, but that only goes so far)?
I'd not change the speakers because it takes times. But I like tweaking stuff and I'd see myself playing with EQ, to get the most our of the system. But once that's done, I'll spend time listening to music.Do you tend to grow bored with same-y stuff
Didn't understand sorry. If the question refer to the look of the speaker, old-fashioned look like the Wharfedale Lintons are nogo. Speakers I mentioned before passed the WAF.What appearance(s) is your partner comfortable with in “statement” furniture?
Hopefully that’s clearer than mud
The KEF R7 are 5y old now from what I see, is it still a good recommendation? I found them at 2200€/CHF, is it considered as a good deal?Regarding speakers: in that price range I'd personally go for either KEF R7 or Wharfedale Lintons (and save some money with the latter). Though maybe the vintage look is not your thing.
Hi !
more or less like this ! (black: concrete, grey: "normal", yellow: windows, orange: where I'd like to put the speakers). floor tiles
The living room alone is 27.5m2, the kitchen is 6m2, so it's 33.5m2 all together, without the corridor going up.Wow, black = concrete… seems like an uncomfortable couch IMO. And you will enjoy the music more if the couch does not face up to the ceiling
Joking aside, it is a complex room. The concrete walls / corners may boost your towers’ bass capability, which can be good. The large windows and tile floor may cause reflection issues, even with DSP, which is not good. Never mind for now as there are ways to help that, both temporary and inexpensive. The original space you mentioned 27m^2 I think - does that include kitchen? It is relevant for SPL and efficiency.
Good. Useful to consider for the specific components’ “relative values” in your longer-term goals. Portions of that budget.
Both of those things (volume knob and good measurements) are available for dozens of DACs at or well below that price point. If you just like the way the Eversolo looks, that’s a different matter.
Good to know you heard at least one speaker on your list. How similar / dissimilar was room size and construct to yours?
Hearing a number of speakers is very useful for considering which characteristics of music playback captivate you most. You’re also correct in assuming hearing too many speakers can become confusing. And if show rooms aren’t available in your area, well, easy answer, eh?
Traditional use. DSP will usually help the main listening spot but often at the expense of other areas.
what? What?? WHAAAT???
That makes your list of options shorter - can be a good thing!
A resolution to keep your choice of speakers makes things much easier if you do not fall into the habit of changing other components (DAC, amp, cables…) expecting them to breathe new life+love into the system as a whole. So I think that’s good too, if you can stay with it.
If you like to tinker in software / settings, I double-down on my recommendation to learn more about DSP, the different devices that permit it (miniDSP is not the only one!), options for integration with various software platforms via server providers, etc. I suspect much of this can be done from your computer with USB mic and active USB cable (to reach the Main Listening Position from computer). Freeware and 30-day trials could really be your friend here.
No worry - you understood. Good - the other three speaker models are pretty typical “modern traditional” appearance, so your options are not much limited by “visual” boundaries.
I definitely have criteria for prioritizing between speaker models that can apply to the three you listed. I’ll circle back to that topic soon once time permits me, in case it’s of interest.
Apollon Hyper NCx500 ST looks like the winner next to similar products from Audiophonics or Nilai500, for Dirac Live PC wait until black friday deals (30% discount), Focal Aria 936 are very nice speakers and they need good amplification (2.8 Ohm dip in low/mid bass area), looks like Apollon is overkill but later when You would use Dirac Live room correction, You will loose some headroom (boosting dips etc, you will need to compensate it in preamp of Dirac processor to avoid clipping), adding 10dB headroom is also important.The living room alone is 27.5m2, the kitchen is 6m2, so it's 33.5m2 all together, without the corridor going up.
I also decided to go for the Factal Aria 936 because there're on sales, the 946 would likely be overkill for my space. I'd need good, beefy amp stable on 2.8ohm region or even lower, to partner with the Factat.
Room correction, OK, but on a miniDSP-like device or on the desktop with Dirac Live software, from where I play my music?
Thanks!
