Thanks, My Pio has a 2.5 mm bal output and my Hiby has a 4.4 mm bal out.2.5mm jacks should only be used directly with balanced headphones or IEMs (those with native 2.5/4.4/XLR plug).
Plugging an RCA Amp into a 2.5mm jack is simply not possible.
Plugging an XLR Amp into a 2.5mm jack is possible, but dangerous due to a lack of GND connection (should be fine on battery power, but I wouldn't do it regardless).
4.4mm jacks can be used with everything, so long as the jack has full pinout including GND.
Going 4.4 to RCA or 4.4 to 3.5 will cut the output voltage in half.
3.5mm jacks can also be used with everything, though feeding an XLR Amp with 3.5mm may not be optimal depending on Amp design.
Depends on what you're planning on plugging into the female side of these adapters.Did I mess up?
I ordered these:
Did I mess up?
thx
bob
I use a 3.5 male to rca cable to go into my integrated tube amp input.Depends on what you're planning on plugging into the female side of these adapters.
Thanks for the heads up! Am I checking continuity and if so what am I looking for?The 2.5mm adapter is a definite no-go then. It will short out the two cold outputs of your DAP, which can lead to permanent damage.
As for the 4.4mm one, I would first check the pinout with a multimeter before plugging it into anything.
You need
4.4 Tip -> Left RCA Signal
4.4 Ring1 -> Disconnected
4.4 Ring2 -> Right RCA Signal
4.4 Ring3 -> Disconnected
4.4 Sleeve -> both RCA GNDs
Thank you! All other connections should be open, then?You're checking for continuity. Here are the only connections you should see:
I would like to utilize the higher power of the bal output...
...I use a 3.5 male to rca cable to go into my integrated tube amp input.
Its worth pointing out those adapters have one real (and very limited) safe use. To convert to (or from) balanced 2.5/4.4 jack to (or from ) 3.5mm balanced jack for headphones. I have one that works fine on a pair of Focals that have an aftermarket cable with a 3.5mm balanced wiring and I use one that converts that to 4.4mm balanced. Im not sure if ANY current headphones come stock with a balanced 3.5mm jack at the amp end for which these adapters would have a use.Thanks, My Pio has a 2.5 mm bal output and my Hiby has a 4.4 mm bal out.
I ordered these:
Did I mess up?
thx
bob
