1N4007 Diode Problem
Alaxleia
Hello,
I meet a question. How can I make a 220V AC to 220V DC rectifier using a 1N4007 diode that can deliver 15 amps of current?
if you can help me? Many thanks
D
Deleted member 46664
Guest
Hello,
You can't. The 1n4007 diode is only rated for 1 amp of current. Trying to pull 15 amps through it will amount to instant failure.
Data sheet attached.
  • 1N4007.pdf
Blumlein 88
Lots of 15 amp rectifiers are inexpensive. Many will be rated for 400 volts or 600 volts, but will be fine with only 220 volts on them.
EDITED: to make it clear, no the 1n4007 diode is a one amp diode and can't be used for 15 amps. You'll need a different diode for that amperage.
wwenze
15 amp you should be looking at something shaped like this at a minimum
DVDdoug
The peak of an AC wave is about 1.7 times RMS and a capacitor will charge-up the peak so, 220V RMS rectified & filtered to regular "smooth" DC is about 375VDC
Full-wave rectified (with a bridge rectifier) and unfiltered is still 220V RMS (a regular incandescent light bulb will light-up to the same brightness, minus the slight voltage-drop across the diode).
Half-wave rectified and unfiltered is 110V RMS (a 110V light bulb will light-up normally with its rated wattage or a 220V light bulb will get 1/4 of its normal wattage).
F
freemansteve
Guest
It won't be as bright as 110V normal AC - there is surely a 50% duty cycle/energy transfer issue with half wave for a bulb.
solderdude
The Neitherlands
Hello,
You can't.
Not only because that diode can not handle currents above 1A but when rectifying 220V AC you will end up with 310V DC.
You will need a 3.5kW 220V DC output AC-DC converter.
So either a 3.5kW transformer with 160V AC output and a bridge rectifier that can handle 15A continuous and you will also need a bunch of 400V DC capacitors and if you need to pull 15A they would have to be substantial in capacitance as well.
Can I ask what that 220V DC would be needed for and why it would need to handle 15A ?
I can't see any practical applications for 220V DC
Waxx
Wodecq, Hainaut, Belgium
First like said, use a bridge rectifier (something like this) that can handle that voltage and current, and put a voltage regulator after (with it to bring the voltage down to the one you want. And i hope you don't want to do this kind of power with a linear psu, this should be an smps and on that kind of voltage and current it's not easy to make.
iMickey503
United States PDX
Use a lot of them in series and parallel and Pray for the best?
If they get hot? Just dunk them in water. What could go wrong? :)
Kijanki
Peak will be at 1.41 of rms value, since Vrms=0.707Vp. For 220V sinewave it will be 310V
