Passive Loudspeaker Speaker Compression/Dynamic Compression
ROOSKIE
Minneapolis
Howdy,
this topic got hot in the JBL 4309 thread.
A lot of very interesting points have been mentioned in that thread.
Let's make the jump to a dedicated thread.
Maybe the mods can move some relevant posts here so there is some context and fuel to work with in this thread.
Things discussed included-
How can we measure and test for loudspeaker compression/dynamic compression?
What are the variables that make it hard to isolate true compression/dynamic compression from other loudspeaker qualities?
How much of a factor is it in practice, how much compression must be present before the sound suffers audibly?
How is it that sometimes compression increases SPL at certain frequencies and other times there is the more likely anticipated reduction in relative SPL?
How does compression/dynamic compression relate to other various distortions (especially HD and IMD.)
& more of course
I think we need to start at high level and define what we want. I think determining some random variable is not going to help us. I push speakers hard in every review and many different manifestations occur. In some cases, no matter how much I crank it up, I don't detect any impairment. In this regard, we want a parameter that would show this. If it shows something else, then it is creating concern where none exists.
In other cases, like amplifier compression, I first hear lack of increase in loudness. This then goes into various types of artifacts such as clicks, pops, static, etc.
In yet other cases, speaker doesn't even play the low frequencies. As such, it gets a free pass even though that may not be correct. Or maybe correct if you intend to use it with a sub or something.
Right now, I find that my ears are super reliable indicators of this. I have not seen any measurements or research that predict what I am hearing. My early tests of a number of speakers also failed in determining such objective limits.
R
ROOSKIE
Minneapolis
Soundstage!, does their "deviation from linearity" test. It often does not corelate with elevated levels in their HD test.
Here is the KEF LS50 meta & the Revel M106 & Triangle BR03.
These are at 90db SPL @ 2m
LS50meta HD
LS50meta deviation from linearity
Revel M106 HD
Revel M106 deviation from linearity
Triangle BR03 HD
Triangle BR03 deviation from linearity
Kvalsvoll
Norway
Ideally, there should be a simple metric, like a spl-in-dB number, that accurately describes the usable spl output capacity of a speaker.
Just measure distortion at increasing levels until a defined limit is reached, may seem like the obvious solution. But this gets complicated, when realizing that the nature of this distortion can be very complex, and some distortion types is less harmful than others.
A compression test will show when compression begins. As for audibility - compression of peak transients at 3dB is hard to hear, 6dB is easy to hear when compared in ABX. But 6dB compression in a speaker is a lot, and very audible distortion artifacts can be present well below that.
The measurement must also be easy to understand and replicate, and widely adapted, to be usable for comparing speakers.
What at first glance seems like a simple thing to measure, turns out to be a lot more complicated.
rebbiputzmaker
If you want to be fair about this there really is going to be no fully reliable measurements at all because what are you really measuring? Maybe even the term speaker is possibly too generic. Each speaker design will have different properties due to the mechanical/physical interactions with the driver. Ported would have different properties versus sealed for cabinets. Too many factors with no control for valid study. Then you have different types of horns and how they are mechanical amplifiers and also affect the driver due other possible interactions. What you’re doing does make sense, although not totally scientific it is reasonable.
ctrl
.de, DE, DEU
Would like to highlight another reason why it is important to develop a "dynamic range" test protocol to determine when a loudspeaker is "dynamically limited".
Definition: A loudspeaker is "dynamically limited" when, at different sound pressure levels, the deviations in frequency response, compared to a reference sound pressure level, exceed a certain limit.
This may not fully describe the "dynamics" of a driver, but it is obviously a basic requirement.
In the thread "Do high-efficiency speakers really have better 'dynamics'?" the majority would probably answered yes to this question.
The 10'' Ciare CH250 mentioned in the thread is a driver with high sensitivity for open-baffle use.
If only 100dB@1m sound pressure level in free field (regardless of the losses due to sound cancellation, 106dB@1m half space) without "dynamic limiting" is to be achieved, then the 10'' driver with +-0.5mm Xmax ([voice coil height - magnetic gap height]/2), may only be used down to 200Hz.
Otherwise, below this frequency, at high sound pressure levels, the driver will definitely show deviations to a reference sound pressure level frequency response. However, we do not have this knowledge (TSP + specification) when testing loudspeaker A from some manufacturer.
It goes even more extreme with the 12'' driver B&C 320K/C-A with a sensitivity of [email protected]@1m, but with Xmax <<+-0.5mm. But to achieve only 100dB@1m sound pressure level in the free field without "dynamic compression", a crossover frequency above 200Hz must also be chosen.
These two drivers could not even be used in combination with a standard subwoofer@80Hz without significantly reducing the "dynamic range" of the whole system..
Similarly with a huge PA speaker with 2x12'' woofer, sensitivity >95dB, that @hardisj tested. Harmonic distortion is good in the low end at 96dB, but at 50Hz there is a significant amount of "dynamic compression" already at 102dB. This speaker must always be driven with a subwoofer.
Without comparative frequency response measurements at different sound pressure levels, this would not have been noticed (Update: I mean the amount of dynamic compression ;)).
tktran303
@ctrl
I agree with everything you say. And this is what makes the M2 most impressive, to me. The midwoofer doesn’t have the smoothest frequency response. But as erinsaudiocorner.com has shown, the bass and sub-bass distortion @96dB between 30Hz and 1000Hz is outstanding H2/H3 below 50dB down and H4/H5 below 70dB down), and the compression between 76 dB up to 102dB is almost negligible, for the entire music bandwidth (>40Hz)
Compare this to the Neiman KH80; another “simple boxed 2 way speaker” that has a higher smoother FR and listening window; and higher predicted preference score. But whilst the former sounds “almost live” the latter sounds like “a small speaker”
tktran303
A lot of people who do drive unit testing have found correlations with what they hear. The objectionable distortion that causes one to hit “stop” in the testing of the DUT is easily determined by ear. But the faint rub and fuzz or whistle-type air noises;sometimes that manifests as higher order distortion, but sometimes it’s not easily visible. I haven’t seen objective information or studies on how to measure that.
This is particularly important for open-baffle speakers; where fuzz/buzz or whooshing noises are particularly objectionable
On the other hand, In my own testing of complete loudspeakers; I can often see distortion that that I can’t hear. Once example is when I see distortion that shouldn’t be there. And then tighten all the screws and it goes away. But I certainly couldn’t those ‘not-fully-tightened’ screws.
aac
PA applications should know a thing or two. Meyer sound has a special signal for that, called M-noise ("music noise" probably).
alex-z
This sort of testing would take a lot of reviewer time because no single metric covers it.
First you have inter-modulation distortion testing. Many 2 way speakers can play loud in a sine sweep, but do they handle strong bass with vocals on top? What frequencies do you select for testing?
You need at repeat the on-axis measurement many times to check for instantaneous and thermal compression.
Plus if you want to deep dive any problems, you start getting into the realm of accelerometer on the cabinet, anemometer on the port, etc.
For the sake of keeping amir sane I would be happy with just instantaneous compression at 3-4 SPL levels. You can spot a lot of basic things like port chuffing or woofer xmax that way.
pogo
As testsignale half sine oscillations of different frequencies at the same time could be used, see also here:
Link
A change in amplitude could also be helpful here to show the limits.
ctrl
.de, DE, DEU
Exactly, between "do not measure at all" and "measure perfectly" there is a gray area that should be used.
Just as the two measurements of harmonic distortion (86dB and 96dB) Amir makes do not cover the whole complex of distortion, a measurement of "dynamic limitations" of a loudspeaker does not have to cover every aspect of the subject.
We (I mean Amir ;)) can also make an intermediate conclusion after ten measured speakers and if the measurements turn out to be useless, stop it. It would only be important that the measurements follow a precise test protocol to guarantee comparability.
pozz
Слава Україні
Editor
@hardisj @amirm
I'm sure you guys know all this, but here's a test regime to think about.
Compression on the signal side is typically expressed as a ratio, input to output:
  • 1:1 means linear output with level.
  • >1:1 is compression, or proportional decrease in output level relative to input. 2:1 means for every 2dB increase in the input signal, there is only a 1dB increase in output.
  • ∞:1 is limiting, equivalent to hard clipping.
  • <1:1 or 1:>1 means expansion, or output proportionally higher than input.
There are also attack and release times (how fast the compression kicks in or drops off, measured in milliseconds) and finally threshold, which determines level. More complex versions might include multiple triggers (multiple thresholds with different ratios), or detection based on crest factor. Multiband compression (different settings for parts of the frequency range) is pretty common.
So function will depend on spectrum, ratio, attack and release times and threshold. As long as we get some numbers we can look up research to figure out audibility.
Some ideas:
  • Plot ratio vs. frequency for a continuous increase in SPL above a baseline. The signal would be a tone increased in level at 12 points per octave, or something to that effect. Take 66dB SPL, around conversational level, and then increase the output 20dB, 30dB, 40dB.
  • Plot level vs. ratio. Take a low level tone, 46dB SPL, and increase it 60dB to identify the threshold where the ratio kicks in.
  • Try to figure out if the compression kicks in or drops off instantaneously or has some time associated. This would be the time in milliseconds that it takes to get from a 1:1 ratio from some compressed ratio or vice versa, to a compressed ratio from a 1:1 baseline. Not sure how to test this.
Not sure how to control for thermal effects. Maybe this can be done with a broadband signal as well, like M-noise, which will simplify the procedure.
For reference: https://www.audiosciencereview.com/...ighlight-dynamic-compression-expansion.26548/
tuga
Oxford, England
What do you think of these two graphs:
5. MIL - Maximum Input Level (intermodulation distortion ≤ 5%)
6. MOL - Maximum Output Level (intermodulation distortion ≤ 5%)
Kvalsvoll
Norway
5. MIL - Maximmum Input Level (intermodulation distortion ≤ 5%)
6. MOL - Maximumm Output Level (intermodulation distortion ≤ 5%)
Maximum output level before excessive distortion, viewed across frequency range like this, can be informative. But this graph looks strange - perhaps they were amplifier limited for this measurement.
But for this speaker, I would rather just eyeball it - 15" good woofer with good motor system + HF compression driver in some kind of smaller horn -> enough capacity for some serious listening in all domestic sized rooms. Just make sure to add a bass-system with decent capacity to fill in the lower frequencies.
Experience with different types of speakers often is all that is required - a typical hifi-speaker with 30hz extension and 2x 6" woofers will never play more than background music, while big 15" and horns usually will be able to play loud enough.
The problem with such an approach is when you encounter something different - like the speakers I make. They are very small, yet claim to be able to play loud enough. Then we need measurements, to show that this is the case.
Using intermodulation distortion for limits can perhaps be a good idea. We know that releaving the speaker drivers that reproduce midrange from bass duty, increases usable capacity significantly, even if the bass is still reproduced from small distorting drivers.
abdo123
Brussels, Belgium
@amirm @hardisj is it possibe to calculate the displacement limits of the speaker using the Klippel LSI module without taking the componoents apart?
I feel that would be the ultimate test of dynamic ability / compression .etc
KSTR
Berlin, Germany
I feel a need of clarification when we talk about compression? More often than not, compression refers to a relative slow sensitivity drift when the voice coil has heated up vs cold state (T_vc = T_ambient). With the long time constants involved, this doesn't cause much distortion by itself, with low level steady state signals after a power burst the driver distorts basically the same, no matter whether hot or cold. But the output RMS level is reduced when the VC is hot (unless the amplifier output impedance is amlost a current source)
OTOH, when the driver is overdriven and clipping, not being able to reproduce the signal anymore, we also measure a reduced total RMS level (or fundamental level) and this can be seen as another form of compression which in turn is not affected much by VC temperature.
Both effects do overlay in practice and to measure one of them correctly would require the other being factored out properly, by choice of signals and procedure/preconditioning. Most likely the second kind of compression will be dominating sound quality deterioration but sometimes the first type can be relevant, for example in small AMTs with as little as ~5W of continuous power dissipation and faster time constants can show a short but significant "brownout" of level after/during a high power burst.
Rja4000
Liège, Belgium
@amirm
Doesn't Klippel itself provide some kind of measurement for this ?
Erins publishes a graph for each speaker showing the Frequency response variations with 3 levels.
He's using Klippel as well, isn't he ?
I find this (with comments) an interesting additional information.
What do you think ?
Here is one from his measurement of the Q150.
