Connecting a umik-1 (usb class 1) with male usb connector to my 2020 macbook air with Two Thunderbolt / USB 4 ports
goryu
Trying to connect my new umik-1 supplied with a male usb class 1 plug to my macbook air with two thunderbolt 4/usb 4 female ports. Can someone tell me what sort of adapter I need? I know there are several kinds of USB and thunderbolt- kind of confusing for someone not on the bleeding edge of all of these protocols, lol...
You need a USBA to USB C adapter. Apple sells one for $19:
There are many alternatives which are way cheaper and work just as well.
Alternatively, you can purchase a USB C to USB C cable and plug your UMIK-1 directly into the MacBook without an adapter:
Same story wrt alternatives.
I've used these with my 2020 Macbook Pro. No problems even with the Umik 1. They are thinner than some so they don't block other ports.
Syntech brand.
Great, thanks!
I assume this would work:
Apple MLL82ZMA 2m USB-C to USB-C Charging Cable​
