Im in middle of a ncore build. harnesses provided by ghent and case as well,. I am looking at the XLR harness and well first off its very short , I mean like nothing to work with at all. second I am not sure what I am looking at.
I have a blue wire, which I am thinking goes to pin 2
I have a "see thru wire I will call grey" which would go to pin 3
and then I have some copper that is part of the casing. but if I look at the harness where it gets close to the connector you can see that the copper isnt attached to anything.
I have Pin #1 grounded to the case already at the XLR backplate.
