L30's warm even turned off. Is this normal?
Don't notice this on mine, it's been off overnight and doesn't feel warm. At the same time it's not stone cold either so depends on your definition of warm
Nope it's still warm (you can feel the heat), but not blazing hot. Left it off for ~12hours. (Machine is off, power adapter plugged to live socket).Maybe leave it over night and check next morning.
I mean. The control part of the circuit is still running. But I don't really think it would be noticeable. Probably it's not as stone cold as something else. I think it's normal.
Probably in China. But meaningless. Impossible to do international.Have you patented NFCA? I think you have mentioned that the approach is nothing new, but It’s your own design and implementation right?
A little bit hotter than it should be I guess it's fine. If it's less hot than on then it's probably right.Nope it's still warm (you can feel the heat), but not blazing hot. Left it off for ~12hours. (Machine is off, power adapter plugged to live socket).
So just wondering if this' the norm.
Moondrop? I contributed to it and inspired the people there.Maybe it's time for Topping to make IEM/headphones?
Ok ok maybe you should start to hang out at Sennheiser HQ then? Start some kind of HD650 next-gen lolMoondrop? I contributed to it and inspired the people there.
"Well I wouldn't put anything past anybody" -SeinfeldMy unit was shipped as promised. Perhaps it’s a demand not economy killing, incompetent legislators.
He already said so, low distortion not very high power class AB of their own design.@JohnYang1997 Side question, do you guys have any plans to do a speaker amp? Maybe a revision of the pa3? I'm still looking for a good performing small form factor speaker amp.
Most likely you'll get it before then. They told me Aug 10th was the shipout date but I received mine on the 6thWelp, L30 not shipping today like it was supposed to. Shipping from Apos delayed till August 26 (let's hope). Shipping upgrade and 15$ credit for future use, can't complain about Apos. I BLAME COVID !!!
From your lips to Apos shipping department!Most likely you'll get it before then. They told me Aug 10th was the shipout date but I received mine on the 6th
I don’t think amps are shipped from Apos. DHLed from Asia directly to your door.
