Emlin
- Joined
- Jul 8, 2018
- Messages
- 1,045
- Likes
- 1,442
That depends on the listener.Headphones have way less soundstage than speakers.
I don't think soThat depends on the listener.
I know so!I don't think so
So you think some people get more soundstage from headphones than from loudspeakers?I know so!
You said that headphones have way less soundstage than speakers.So you think some people get more soundstage from headphones than from loudspeakers?
By and large I have a soundstage that is acceptable, given the room size (3.9m x2.6m x 1.2m high)
As this recording is of "The Marriage of Figaro," it's quite possible the singers were moving around. Some opera recordings in the early stereo era were staged - London's recordings notably. Considering how important movement is in "Figaro," I could easily imagine this recording was at least partially staged, even if it is slightly outside the time window when the practice was fairly common.
It would be no surprise if this recording were captured by some variation on the Decca Tree, a trio of omnidirectional (or nearly omnidirectional) mikes, rather than something more like an ORTF set up.I also think the singers are moving around based on the YouTube video I posted on the previous page (if that is the recording OP was listening to?).
Suppose the recording was made with a stereo pair of microphones with a directional pickup pattern and placed not too far apart. In that case, it's likely that when the singer moves a bit from right to left on the stage, the sound of the voice changes from being dominated by the right microphone to being dominated by the left microphone. If the two recordings by those two microphones are then hard-panned, one to the left and the other to the right, it could explain why the singer seems to be jumping from one point to another in the stereo field even if the (s)he's not, in reality, is moving that far on the stage as it sounds like.
The above is what I think is happening here. I find it unlikely that the directional behavior of OP's loudspeakers will make the singer appear to be coming from different positions in the stereo field if nothing else (like instruments) is moving around too.![]()
Have you checked that your hearing is OK and the same on both sides?Hello,
I am a bit reluctant to post this, as I don't know if this is a basic beginners query or if it is a complex matter, but I have not yet found a direct answer to it, apart from the item in the thread referenced below*
By and large I have a soundstage that is acceptable, given the room size (3.9m x2.6m x 1.2m high) and the equipment (noted below). In most of my listening voices and instruments are satisfactorily separate in the soundstage but not pinpointed (although I do not know if they always should be).
However,listening to some opera I heard a couple of odd things, so here are 2 examples:
Ex 1. Nozze di Figaro – Act 1 scene 8 No 10 – Aria. For me the male voice (baritone) starts left of centre and moves to centre and back again as the power of the vocals increases and decreases. This also accompanies an apparent rise and fall in pitch.
Ex 2 Act 2scene 1 No 11 – La Contessa - definite movement from left of centre towards centre as pitch /volume increases, then back as these decrease.
The apparent distances moved seem unlikely to coincide with on-stage movements by the performers.
The next example did not behave the same:
Ex 3 - Act2, scene 2 No 13 Susanna's Aria – very little apparent movement.
I have also noticed a similar issue with electric guitar in at least 1 other audio track. Here my impression was that the instrument moved from right speaker some 10/20 degrees towards centre, then back again as loudness/frequency fluctuated. (I give this example to rule out a specific single speaker problem).
Based on my examples it seems possible that this effect happens at the change between tweeter and woofer in my speakers (Linn Katans,) as this area coincides with a large part of the human vocal range. If the crossover is the reason for the apparent soundstage issue, how could I test this? (I have REW+ Umik-1).
There are no manufacturers published figures for the Katan's crossovers.
Alternatively, is 'directivity' (or poor implementation of) the issue?
Does this apparent effect have a common name (that I could search on)?
If anyone can confirm my suspicions or offer alternative explanations, please do so!
My current set up is: Rpi4/Moodeaudio 9.1.3 → Denon X3600 → via preout to Linn AV5125 containing active crossovers for Linn Katans. MLP is 1.8mfrom each speaker, which are 1.75m apart and 0.6m from the front wall.
* thread in ASR -“Soundstage, and how much influence can audio equipment have”
Quote from DonH56 Aug10 2018 “And a speaker that does not integrate the drivers well will exhibit changes in soundstage and image as pitch goes up and down and so forth.”
I realise this may not be practical but have you tried rotating the room layout 90 degrees so that the speakers are in front of the longer 3.9m wall? This way your first reflection points are much further away and the direct sound from the speakers should be more dominant in your listening. Even if you are able to temporarily try this just to ascertain if the early reflections’ contribution to the sound (and its inconsistency) in your existing layout are a factor.By and large I have a soundstage that is acceptable, given the room size (3.9m x2.6m x 1.2m high)
I didn't mean to twist your words, I just haven't seen any evidence myself that some people get near loudspeaker levels of soundstage from headphones. If you watch The Headphone Show on YouTube I don't think any of the presenters think headphones offer anything like the soundstage. 15% is a figure I've seen them mention.You said that headphones have way less soundstage than speakers.
I said that that depends on the listener.
I did not say that anyone gets more soundstage from headphones than loudspeakers.
Please don't try and twist my words or you'll get taken for a troll.
I am one of those that does.I didn't mean to twist your words, I just haven't seen any evidence myself that some people get near loudspeaker levels of soundstage from headphones. If you watch The Headphone Show on YouTube I don't think any of the presenters think headphones offer anything like the soundstage. 15% is a figure I've seen them mention.
@goat76
Based on the performers, conductor and the date I think we are dealing with the same recording.
On my version of the recording, Act 2 Sc X, the baritone is solo at approx 21 secs from the start of the scene, and is just to L of C on my system. As the second verse/phrase begins some 10 seconds later the voice is notably about halfway between C and R. It is possible that both Figaro and Il Conte are involved here. Is this the section that you have isolated in your 2nd response?
To do this, you would first need to look into in-the-head localization with headphones and out-of-head localization with loudspeakers.I didn't mean to twist your words, I just haven't seen any evidence myself that some people get near loudspeaker levels of soundstage from headphones. If you watch The Headphone Show on YouTube I don't think any of the presenters think headphones offer anything like the soundstage. 15% is a figure I've seen them mention.
