My class A (J2) has plus and minus supplies and a totem pole output, so the output does swing plus and minus.
That one had to come up, didn’t it
Read AMIR’s review of the Nad M10, he isn’t happy over the digitisation of the amplifiers analogue inputs.Not quite:
It’s just a Hypex or Purify amp with a marketing enhanced DAC in front of it. And they state the amp is analog:
It swings + & - around the quiescent current setting, the - is a lower level of +.My class A (J2) has plus and minus supplies and a totem pole output, so the output does swing plus and minus.
So? It's an integrated amp with room correction, and therefore it has an ADC/DAC chain. That doesn't make it a digital amplifier. If so, then every AVR with a class AB amp is a digital amplifier as well.Read AMIR’s review of the Nad M10, he isn’t happy over the digitisation of the amplifiers analogue inputs.
Oh my god.So? It's an integrated amp with room correction, and therefore it has an ADC/DAC chain. That doesn't make it a digital amplifier. If so, then every AVR with a class AB amp is a digital amplifier as well.
Let's make it simple and take a power amplifier, for instance, NAD M23. Is that a digital amplifier? Why?
True, but at the load end the voltage swings plus and minus. Although I begin to see the confusion here.It swings + & - around the quiescent current setting, the - is a lower level of +.
If the quiescent current is set at 10A and the signal goes negative by 2A, it is still +8A.
Once you've made the commitment, you've got to see it thoughOh my god.
You two are still at it??
In absolute terms, a pure single ended class A amp, or one half of a differential class A amp, does not change polarity! It swings from quiescent/bias point up and down, if it touches zero, that's it. On a single ended amp, that's a clip, on differential, that's class B. But never goes past zero.True, but at the load end the voltage swings plus and minus. Although I begin to see the confusion here.
You're right that the current never crosses through zero. Otherwise yeah, it's just arguing on the internetIn absolute terms, a pure single ended class A amp, or one half of a differential class A amp, does not change polarity! It swings from quiescent/bias point up and down, if it touches zero, that's it. On a single ended amp, that's a clip, on differential, that's class B. But never goes below zero.
In a differential output stage, the DC from each half cancels out when the two halves are combined.
But this is all irrelevant to the subject at hand, No?
Argument for argument’s sake?
The M23 is described as being a Hybrid Digital Amplifier. Think you need to look up the definition of Hybrid.So? It's an integrated amp with room correction, and therefore it has an ADC/DAC chain. That doesn't make it a digital amplifier. If so, then every AVR with a class AB amp is a digital amplifier as well.
Quit quoting the marketing department Good luck with your vegan chicken wings though!The M23 is described as being a Hybrid Digital Amplifier. Think you need to look up the definition of Hybrid.
I like how they cleverly spotted Hypex modules. Not much gets past these guys!Quit quoting the marketing department Good luck with your vegan chicken wings though!
So AMIR and Nad are wrong. You remind me of the Mother who goes to watch her son’s army cadet passing out parade,Quit quoting the marketing department Good luck with your vegan chicken wings though!
Why don't you actually address any of the questions I posed to you? I clearly explained why the M10 has a DAC and ADC. This is not part of the power amplifier section. It's just an integrated amp with digital inputs and room correction like there are a great many out there. The room correction is the reason for the AD/DA conversion, nothing else.So AMIR and Nad are wrong.
What's up with all of these ad hominems? Why not come up with actual arguments for onceYou remind me of the Mother who goes to watch her son’s army cadet passing out parade,
As his platoon are passing she turns to her husband and says, “Look Dad our George is the only one in step.’
If it’s got an ADC inside the amplifier the signal is converted from analogue to digital. An amplifier after this is amplifying a digital signal. A hybrid amp has more than one method of amplification.Why don't you actually address any of the questions I posed to you? I clearly explained why the M10 has a DAC and ADC. This is not part of the power amplifier section. It's just an integrated amp with digital inputs and room correction like there are a great many out there. The room correction is the reason for the AD/DA conversion, nothing else.
NAD is plain wrong with their Hybrid nonsense. It's just a marketing term and nothing else. If you would actually take the time to read the "white paper" I posted, you'd know what it's all about. By that definition, the M23 shouldn't even be called HybridDigital, and for some reason, it still is... Yeah, I know what is coming: "you see, they admit it's digital right there after all".. Sorry... no, it's just stupid marketing, nothing else. If you think otherwise, tell us what is digital about the M23? Also, tell us then how the designer is wrong about telling everybody it's an analog amplifier.
But the M23 doesn't have an ADC.If it’s got an ADC inside the amplifier the signal is converted from analogue to digital.
But does not. The integrated NAD M10 just has a DAC, and the signal goes analog into its power amp module.An amplifier after this is amplifying a digital signal. A hybrid amp has more than one method of amplification.
Yeah, I already posted that. It got thoroughly strawmanned already.According to the guys who designed the amplifier modules NAD uses ...
On the ADC just quoting what you said in post 97. My fault for taking anything you say seriously.But the M23 doesn't have an ADC.
Remember, we're talking about the amplifier topology here. It's like a petrol vs an electric car. You argue that because the gas pedal of a petrol car is fly-by-wire, it's a hybrid.
That's a different amp . I explained twice why it has an ADC and It has nothing to do with amplifying. To remove the confusion, I opted to discuss the M23. It's a power amp only, equivalent to discussing a car engine, and not the whole car. Clearly, you are incapable of making the distinction between the two concepts.On the ADC just quoting what you said in post 97. My fault for taking anything you say seriously.
