What is the better wiring for a DAC? Long USB cable vs. long unbalanced RCA?
voodooless
Netherlands
This scheme won't work?
That is NOT a network interface, though it looks very similar. This actually (tries to) transport USB over the ethernet cable. It may work for you. But seeing the negative reviews there seem to be some issues with cameras, which may have similar amounts of data bandwidth needs.
Vincent Kars
As I said before, check if it supports USB in High Speed mode. They don't say so and looking at the devices in the picture, they are all low or full speed.
This one does
boxerfan88
Looks like boxerfan88 has already implemented this. I would want to do the same, except with short RCA cables from the DAC to the preamp.
Yes, I am using daily. I checked my Shopee order, small correction, I am using 10M extender, with dual amplifier. Here is the screenshot of the item that I bought. Ensure you choose USB3. You’ll have to search for it at your favourite online store.
P
paulg1
Thanks, boxerfan88. That is available and reasonably priced in 10m length.
