Using MSO with MiniDSP - best process?
klettermann
Coastal Connecticut
The more I learn the less I know. As result I'm back to more fiddling with room EQ and sub integration, cause I'm sure I can do it better. My toolbox consists of MiniDSP Studio, REW, Dirac and MSO. It's a 2ch system with 2 subs and large Magneplanars. I'm less concerned about multiple listening positions than best possible result at the MLP. As usual, the issue becomes "what's the best approach?" I've settled on:
  1. MSO for the sub integration
  2. REW to EQ the mains. Maybe also Dirac, though to date I've found REW EQing to sound a little better.
  3. MiniDSP for XOing, level matching, any final tweaks.ing, etc.
There's nothing new about this, pretty mainstream. However, there seem to be a zillion ways to use MSO and integrate everything. Fortunately MiniDSP offers what seems to be a relatively easy way to do it that perfectly fits my use case HERE. So here's the question: Does anybody have experience with this particular process? Caveats, pros, cons? Any comments welcome, thanks in advance and Cheers,
