klettermann
MSO continues to amaze me. My current challenge, apart from a zillion[^zillion.exp] configurations and just figuring out how to use it at all, entails how deep to go. AND, simply recognize what problems I'm trying to solve.
Specifically, it only now dawned on me that the Multi-stage optimization requires shared filters that end up being integrated into crossover filters for the respective sub channels. So, the optimization output consists of respective sub EQ biquads and XO biquads (the *_xo.txt fies). There's also another biquad " Config **.txt " file. I have no idea what that's for. Then, you use the *_xo.txt files for the sub LPFs.
Is this understanding correct? If so, then wouldn't it follow that those shared filters be designed such that they can work as the XO LPFs? Of course I wasn't doing that and ignored the *_xo.txt files and the results were obviously ridiculous. I'll go back and try to figure out the single Config*.txt biquad but if anybody comments that would be great. Hope this is clear?
Thanks as always and cheetrs,
. For starters I'd like to get the subs properly aligned, EQing the mains and putting them together. I've figured out how to use REW to do this pretty well - but I'm sure that MSO can do a better job with the subs. What I envision as an end point are four MiniDSP configurations, maybe 2 using Dirac and 2 using just REW tweaking. The listening area is a small couch. I'm not trying to cover a wide or deep listening area. It's just MLP 95% time and otherwise at most two (friendly) listeners.
