Using a Raspberry Pi as equaliser in between an USB source (iPad) and USB DAC
Red@
I provide below the starter for the gaudio_ctl daemon required to launch the script mentioned in my previous post (file set_samplerate.service under /usr/lib/systemd/system):
Code:
[Unit]
Description=Sample Rate Changer Daemon
After=multi-user.target
[Service]
ExecStart=gaudio_ctl --gadget-name "UAC2Gadget" --ccmd  "/usr/bin/python3 /home/pi/set_samplerate.py {R}"
Restart=always
RestartSec=1
StandardOutput=journal
StandardError=journal
SyslogIdentifier=set_samplerate
CPUSchedulingPolicy=fifo
CPUSchedulingPriority=10
User=pi
Group=pi
[Install]
WantedBy=usb-gadget.target multi-user.target
Note the "WantedBy" option in the [Install] section ensuring that the sample rate change daemon is started when the usb-gadget.target is reached, indicating the aviailability of a usb gadget device (this was suggested by @phofman elsewhere).
Hello @stemag,
I am not a dev per say, and would like to use this solution. since the infomation is quite scattered between posts, I am a little at lost.
Would it be possible for you to describe the steps including you're latest additions ?
It would he very much appreciate, thank you very much in advance
stemag
Hello @stemag,
I had the same difficulty in putting all the information together. Now everything is working as expected.
I will try to write a small guide. Please allow me a few days.
stemag
Please find attached a small guide to set up a DSP box based on Raspberry Pi 4 hardware and CamillaDSP software.
I am not a native English speaker, so I apologise for any imperfect use of the English language.
Please inform me of any errors or omissions.
  • HowToSetupCamillaDSPBox.pdf
melomane13
France
is this adapter ok for gadget?
Convertisseur-de-Type-C-OTG-adaptateur-de-c-ble-de-Charge-rapide-USB-C-USB-3.jpg_.webp
phofman
That USB3 (i.e. data) connector is female (i.e. host side). You need a device side connector, to be plugged into a host.
melomane13
France
Do you want to go deeper? I'm not sure I understand
phofman
IIUC you are looking for a splitter to power your RPi while using the USB-C as a gadget (that's the subject of this topic). If so, the splitter would have to present the device side of the USB connection.
Music1969
Hi @phofman , so do you have automatic sample rate switching working with your Pi4?
So if Apple Music Hi-Res changes sample rates, you can feed it bitperfectly into Pi4, without any manual changing of sample rate?
What are the key code lines required for this to work ?
Or is it now part of some mainline kernel for RPi4?
phofman
phofman
Thanks! Looking at the thread, seems only the OP was able to get it to work, and nobody else.
IIUC there was only one follower who really tried and did not know how to compile C code in linux. Another guy did not use the USB gaget device.
I have not tested the project but it looks nice and the author is clearly very competent.
melomane13
France
Gadget setup as explained here work with Raspberry zero w 2: i have relied pc to raspberry with direct câble.
BUT , because i have USB sound card, i have add standard USB hub and now gadget is not show.
Some USB hub are sell as OTG ( not mine) , do you think can be work?
Édit: not possible to have on the same port, slave and master.
phofman
The dwc2 device on RPi can be either host or gadget/device, not both at the same time. If you need both, you need two USB controllers, such as dwc2 and VL805 on RPi4.
melomane13
France
Ok, thanks . The question is: It Is possible add a second USB controller on ZERO?
IAtaman
I did not fully understand what is it that you are trying to acheive, so if question is stupid, you know why :
Zero W has 2 USB Ports, OTG/Power port and the host port. Why don't you connect the USB hub and sound card to the host port, and leave the OTG/Power port connected to the PC?
IAtaman
As there is no PCI-e port available on the Zero, there is no interface to hook a USB controller to.
Either a standard-format RPi, or almost all other non-RPIs - e.g. most Radxa boards have 2x USB controllers with 1x OTG capability https://radxa.com/products
My favourite is Rock Pi S. It is smaller and has a convenient form factor, comes with a USB-C OTG /power port, ethernet port and a USB A host. One of these little guys is running CamillaDSP successfully for months now for me. You can get the one with Wifi and BT for ca $25 on aliexpress.
