usb redriver
doitttt
put redriver in between from laptop to dac
A "Reclocker" performs an UP-shaping of the waveform of the digital signals with additional low output impedance, so that the cables' capacitive
load and any impedance mismatch have no or - at least - minor importance.
The sharper the digital signals are, the more precisely the signal is processed the rest of the way through the DAC. That's what you hear as
result of
https://dk.rs-online.com/web/p/kommunikation-og-tradlos-udvikling/2659953
gives better sound
DVDdoug
A solution looking for a problem.
There are rarely audio problems caused on the "digital side" and if you do have digital corruption or errors the sound is usually terrible.
This is the beauty of digital... As long as a "1" remains a "1" and a "0" remains a "0", everything is good. Digital data goes all over the world (including this thread) through all kinds of wired & wireless connections with no problems.
Timing errors and "jitter" are normally way-way too small to he audible, except if the clock in your soundcard is off the speed & pitch can be off, or if you are sending real-time data over the Internet it can get interrupted and you can get glitches/dropouts.
Ron Texas
Sometimes placing a USB2 hub between a DAC and a USB3 port will solve a gross problem like stuttering.
D
doitttt
usb redriver only converts pure square signal
much better all decrap you put to the usb port
popej
It is a circuit for active USB cables, usually with length of 5m or greater. You should use one for a remote DAC ;)
wwenze
result of
gives better sound
Isn't it interesting that the reference documentation linked always do not contain any mention or support of the claims being presented.
kchap
Melbourne, Oz
I think redriver is designed for the Gb/s speeds of usb 3.n devices, not the Mb/s of usb 2 devices. As far as I'm aware all the usb DACs tested and/or discussed in ASR are usb 2. In any case its function is to ensure that even where the io chipset is some distance from the usb connector, the signals at the connector will be compliant.
Just to clarify a fully compliant usb 3.n connector will have 2 sets of data lines. A tx and rx pair carrying at least 5Gb/s full duplex usb3.n data and a single half duplex pair carrying up to 480Mb/s usb 1/2 data.
D
doitttt
the usb cable with redriver works like an optical cable
with pure square curves it behaves like optical cable
if you don't, read some more literature
NTK
US East
From the video transcript. This device is for high speed signals transmitted on long signal paths that can cause signal attenuation and signal timing problems, which will result in data corruptions.
These input and output eye diagrams are from the TUSB501 datasheet. If your eye is not stressed like the first (input) diagram, there is no benefit to using this redriver. Notice that the data rate for these signals are 5 Gb/s.
And the signals are not "pure square waves". If they are, you are leaving a lot of bandwidth on the table.
kchap
Melbourne, Oz
The redrivers are:
  • Equalizers, they do not perform clock extraction, re-timing and re-shaping. Thanks @NTK
  • Work on the 5Gb/s usb 3.n signals, not the usb 2 signals used by most DACs.
  • Intended to cleanup usb 3.n signals across circuit boards.
They are a waste of time for DACs.
voodooless
Netherlands
The redrivers are:
No, the board contains two chips, also one for USB 2.0.
Yes!
No it does not! There is no galvanic isolation, there is no signal conversion.
We still haven’t seen you prove it improves audio quality…
popej
3 meters its max
In most cases, you don't need redriver for 3m.
fpitas
Northern Virginia, USA
I'll reiterate: that's not what high-speed digital ever looks like. See the eye diagrams in post #12.
fpitas
Yes, but somebody wants you to buy their goofy gizmo nonetheless.
