When plugged into the mains with a switching power supply plug it’s silent but when I power it from usb (only needs 5v and has a barrel jack) I get some hum. It’s a DYP au-d3-192 small DAC.
Got some average usb to barrel jack converter cables to try and saves a plug on the wall being used but now get hum
Have swapped over between the usb lead and mains lead and it’s definitely from the usb power supply.
Happens on both coax and toslink options to the DAC so not a grounding issue further up the line.
The usb hub is a 4 way charger and gives 2.1amp per connection.
Is it worth trying a ferrite bead on the usb lead or anything else I can try?
Cheers!
Simon
Cheers!
Simon
