kevin gilmore
- Joined
- Feb 29, 2020
- Messages
- 57
- Likes
- 282
same problem i have with toroidy transformers. shipping exceeds the part cost.
The EHA5 has 6dB higher gain with RCA in to compensate for the 6dB lower signal amplitude that RCA Line out typically has, compared to XLR.I just realized looking at the specs that there is higher gain on the single ended RCA then the balanced XLR.........does that mean the amp will be louder if you use the RCA connection?
I just assumed XLR would be louder, anyone tested this?
at no audio frequency can the eha5 generate 700vrms without the amp going into shutdown mode. bob katz and others have tested this.
the nfca modules are limited to about 4 watts of power output, and that is nowhere near enough to drive those transformers.
a pair of edcor transformers and a bias supply ends up about $450 in parts. really excellent for the price. you still need a good 60 watt power amp.
Thanks to @Aokman for his inspiration and advice, along with @kevin gilmore for answering questions. This setup sounds fantastic. Easily puts out over 2kV down to ~13Hz with a perfect looking sine wave. 10Hz will go up to ~1400Vpp before starting to distort a little. I stopped my testing a little over 2kV, but I had more headroom left when running the AHB2 in bridged mode for most frequencies even at 2kV!
All sine wave measurements posted are of the transformer setup. Of course, the BHSE can do 1500Vpp at 10Hz with a beautiful looking sine wave. Getting ~1400Vpp @10Hz from a transformer setup with a clean looking waveform is really good though; a little higher in Hz and it has more bass output than a BHSE (as the 20Hz 2kV measurement shows, was also getting a clean waveform at 13Hz@2kV). Up to you if you need the extra volume and additional bass output or not. A lot of people really like the LL1630's. As aokman shows in his video below, they are a little lacking in the low end, but otherwise have an outstandingly flat resposne without any additional components.Also that 10Hz sine with distortion, was that the BHSE or the transformer + AHB2?
Im testing an Edcor output transformer currently based on a recommendation from Kevin, it definitely won’t run bare linearly like a LL1630 but it definitely has far more capabilities with some external resistors etc… Ill be doing a video on it shortly as soon as I finish my audio analyser…so far I see only Lundahls being used for these DIY builds. Would output Transformers meant for EL34 Amps (hooked in reverse), also be good candidates for such a build?
a SRD7 replaced my blue Hawaii. If you like to listen to headphones with eq or/and on the louder side, all dedicated stax amps no matter how big will start to distort when pushed, transformers are the only solution.Can someone summarize in layman's terms the safety and quality of the EHA5 as opposed to something in the same ballpark like the newer Stax SR-270 (seems to replace SRM-252S)? I' m not sure if there are other sub-1000 new options or whether the 270 is meaningfully different from 252S which is what I'm using for L300 Limited, but I can tell the 252S is a limiting factor.
What amp do you use for the SRD7? A cheap Fosi Audio FA3 gives a very good performance when changing all the op-amps for better. Amp is only 150€ but op-amps 300€a SRD7 replaced my blue Hawaii. If you like to listen to headphones with eq or/and on the louder side, all dedicated stax amps no matter how big will start to distort when pushed, transformers are the only solution.
any stereo amp with good thd+n/sinad, a gain of 30dB or more (or add preamp if needed), and about 10Watts or more into 4Ohms is all you will ever need really.What amp do you use for the SRD7? A cheap Fosi Audio FA3 gives a very good performance when changing all the op-amps for better. Amp is only 150€ but op-amps 300€Sound a bit of tube and solid state, like a hybrid. The treble stays in better control. 150W/4Ohm is sufficient. I can't use High gain from the Schiit Magni when using XLR input but sound is much better than RCA input. I have the Ifi Audio iESL.. So lots of power is needed for Nectarsound HiveX.
@etc6849 How loud do u listen to music? It's just crazy how much power there is for one channel. I'm happy with Fosi Audio ZA3 with paired Ifi Audio iESL. No clipping!
