Wow, that’s not great.It's worth to mention that EQ is only working with USB input!
You also need the physical space on chassis for the ports!
I'm not sure enough people appreciate how much work goes into stuffing so much functionality into such a small package!
Thankfully there are 86,749 other DACs on the market that meet your needs.I don't really care how small the package is. I'd rather have XLR jacks and a display that's larger than a postage stamp.
Well yes, but the Topping is already at -120 dB, below the limit of audibility, this is what counts. If you chuck in additionally -180 dB to make Rob Watts happy, nice, but does not affect sound quality.You can see the difference here as an example:
Topping EQ:
RME EQ
(from this thread where it also mentions a similar Bluesound problem)
You can also see it here (where it was the cause for a partial fix and it's a really good read down the thread as it addresses lots of aspects)
Balanced outs over 1/4 inch?
That's amateur hour.
Why?
easy, buy two and get 10 per channelWe also have to mention that EQ is applied to both channels and (until now) there's no way for different settings on each channel.
That makes Room EQ very difficult but I guess is good news for headphone users.
It's a start though.
Nope,the quality of RME's filters is still out of reach by these companies,including miniDSP which makes stuff like this for a long time.
Otherwise really nice measurements.
Thanks Amir!
I'd quite like to see @amirm maybe measure a typical headphone EQ (complicated overlapping filters, perhaps one of Oratory's EQ's) in the Topping for noise issues, and perhaps measured vs a software solution like Roon. If this is a technically feasible thing to be done.What I have seen measuring filters like that (the miniDSP Flex that I returned) is that the noise increases as we go lower in freq.
Number of filters doesn't help either.
There's a thread about it but gathering info after that it seems that many suffer the same and only top implementations like RME's seem to solve it.
Plastic PC mount TRS jacks can't handle much stress before breaking or solder connections fail.
Is this ... my first topping purchase?
Both will obviously be a lot more expensive. But at least D90 III D will give PEQ on all inputs. I think for the price though it should also include a headphone amp.depending on your needs, wants, and budget you might want to hold off till we get some more details on the D90III D.
TOPPING D90 III、TOPPING D50 III
Figures, anyone successfully update one of these Topping bits of kit from a linux box? I did a cursory search and didn't find much information. Given that they have warnings about bricking your device by flashing the wrong firmware, I'm very hesitant to experiment on my just-shipped device.www.audiosciencereview.com1 bit DAC launched by TOPPING
I guess you’ve never set foot in a professional studio?
