Topping D50 barrel connector SIZE
NormB
Been all over the web on this one.
OUTSIDE diameter of the 5 vdc connectors are definitely 5.5mm, but what’s the INSIDE/PIN diameter? 2.1, or 2.5mm?
I’d like to order a “better” connector (like Oyaide from Ghent Audio) with a shielded cable instead of using the 20 gauge 2-lead zip cord supplied with the D50.
I sent them an email, but I don’t expect an answer. Thought I’d ask here among the audioscenti.
Thanks in advance.
Norm
Berwhale
This is the cable that connects my D50s to my P50 PSU...
NormB
NormB
you’re measuring between which two points? The plastic or the metal contacts.
I did this and came up with EITHER 2.1x or 2.5x (I don’t recall the hundredth decimal place) depending on which, but the metal contacts measured WIDER which didn't make any sense at all.
Thanks.
NormB
NormB
Noise on the supply line is already way higher than any typical external interference. zip cord is fine, really.
I’ll take that under advisement. I’m not one of these guys who buys into the voodoo magic buckeyball sauce, but it just seemed like a good idea.
I also want to get one for my phono stage linear PS to amp connector.
I might just BUY a pair of connectors (like old radio shack stock, or on my next Mouser order) of the 2.1 and 2.5 variety and see which one fits. I have some other projects I can use them for sometime.
Thanks again.
Norm
Berwhale
Thanks.
The metal contacts, with a little pressure applied (they move, which may be why you measured a larger gap).
BTW, The P50 product page states that the connector is 5.5/2.1...
NormB
NormB
Or the metal contacts are a little cockeyed/bent.
Did this AGAIN (I'm an old hand with micrometers/calipers/verniers - some of my hobbies are gunsmithing and high-power rifle handloading), got a GOOD look at the contacts and they're really oddly shaped, kind of beveled (like some tube socket contacts) MOSTLY I get about 2.13-2.15mm readings. Had to use a 4.0 diopter magnifier hood to see well - yes, ophthalmology appointment's on my "to do list."
Thanks again.
Berwhale
As an aside, both the D50s and A50s have 5.5/2.1 barrel connectors for power, but the A50s is 15V, rather than the 5V for the D50s. It's very easy to mix them up, but at least they are both DC. My D50s was originally paired with a JDS Labs Atom which also had a 5.5/2.1 connector, but running at 15V AC which I don't think the DAC would like.
NormB
NormB
Wow. I honestly didn’t expect an answer - at least not so soon- but here it is, straight outta customer service:
