Did this ever get sent to Amir? I'm looking for something that can hopefully work with my Genelec and Kali system and even without from correction just do the volume adjustments so I don't have to.
I’ m interested in why it is a problem that the at300 has a crappy room correction when you have genelec with glm? Couldn’t you use the glm soft?
I’m asking because I will probably build a genelec home theater (83xx or g4/5, not sure) and a Chinese av preamp with xlr is golden !
Even though I’ll miss the hdmi2.1 for the ps5 and the 3080ti… they’ll go directly to the tv and the pre will have an optical feedback for these two.
I was looking at the denon, especially the 3700, quite cheap, but rca only, I don’t know if it is a big deal or not with a genelec set up. If it is ok, it is probably a better option in my case.
Concerning the genelec, since you are a owner, I’m a bit puzzled about the sound level they can output.
I’m considering at first a 3 way system then a 5 one.
My listening room is 6 x 5 meters (2,40m high), I’m approximately 4m50 away from the l r channel.
Will the 8340 (8350 ?) be enough to have a home cinéma experience ? Or the g five ?
