- Thread Starter
- #21
I’d respectfully disagree having heard a few tryDeath metal is actually a very technically demanding genre, my guess is a lot of those guys could actually become passable jazz drummers without too much re-training.
I was thinking something similar the other day. We went to a live classical concert of a chamber orchestra playing 21st and 19th century music. The sound was so dynamic and yet so clean and clear, such as one rarely if ever hears from any recording, even with outstanding equipment. And yet, I know CD Red Book should make this possible in a recording.Where have all those 24 bits gone!?
The problem is not always even the recording, its your loudspeakers. For example, a drumkit can go up to 130dB. Can your speakers do that without compression?Had the joy of listening to a live jazz trio up close tonight. Unbelievable dynamics - from the most gentle brush work to pounding accents. From a whisper that we strained to hear to a musical cacophony (in the best sense!)
The compressed recorded jazz I hear at home just doesn’t come close - even the good stuff. I feel like we’ve been cheated of everything digital promised us. Where have all those 24 bits gone!?
They certainly cannotThe problem is not always even the recording, its your loudspeakers. For example, a drumkit can go up to 130dB. Can your speakers do that without compression?
Thanks for this - my last post crossed over with yours . Where is line between playback practicalities and trading dynamic range. In the specific context of an acoustic jazz Trio ? Subjectively I guessThe issue is that such a recording would be very problematic at normal listening levels, and also on systems that cannot reproduce the dynamics of a live event (which means most systems).
Yes and the first thing to go is the real thump off the kickdrumThis is pretty simple. To get the dynamics of a live event, you must play equally loud at home. So transients exceeding 100-110dB on a regular basis.
If the recording is to preserve that level of dynamics, it must be mixed and mastered in such a way that if you were to turn the volume down, the most quiet parts of the music will be inaudible. This is perfectly possible with regular 16 bit CD (no 24 bit needed).
Yes and the first thing to go is the real thump off the kickdrum![]()
Different context and specific to my gig - it was a little 18” jazz bass drum tuned a little high so more a booing than a boom.Yes and the first thing to go is the real thump off the kickdrum![]()
I think Bob Katz's K-system gets close to the amount of compression that is not over the top and takes into account practical considerations. It can take some studying and thinking to wrap your head around it. Once you do however it is not really complicated and quite sensible.They certainly cannot
I think the genre and style helped in this instance - the drummer had to play to a sensible level to balance against a double bass and Steinway. I was a pretty close and it was never painfully loud . It was the dynamic contrasts that really stood out.
Thanks for all the interesting comments, really interesting and informative . It’s great to get different perspectives from you.
I understand why we might need an amount of dynamic compression - I wonder where the tipping point is between practical considerations for playback and losing the naturalness of proper dynamics ?
Many thanks for sharing this.I think Bob Katz's K-system gets close to the amount of compression that is not over the top and takes into account practical considerations. It can take some studying and thinking to wrap your head around it. Once you do however it is not really complicated and quite sensible.
That's an interesting interpretation. Where do you get 256 levels from? 16^2? There are 2^16 = 65,536 "levels".The way I've come to understand it:
The extra 8 bits (from 16 to 24) are hiding within the least significant bit of the 16 bit recording.
It gives the possibility of more "precision" of the digital value (256 levels between smallest "steps" of 16 bits.
And reduces the all-but-inaudible noise of the imprecision of the indecision for the level of that 16th bit, taking it from 90dB down from the peak level to -140dB (or thereabouts).
As mentioned in the prior post, if you want "live" sound, crank it up (cleanly).
I think in that case the listening room is actually the bigger limitation.Assuming the “perfect” recording, what would the specs be of a loudspeaker system that could in fact come closest to the ideal transducer to replicate the live event, especially dynamics?
