I need integrated amplifier with small footprint. It will be very visible so I want it to look good. And have vumeters
As much as I could find, my only choices are Teac AI-503 and AX-505. Which one to choose?
AX-505
Pros - newer, more power (Hypex NCore 70/115W into 8/4 ohms)
Cons - less inputs, no pre-outs
AI-503
Pros - more inputs (optical, bluetooth), has pre-outs
Cons- older, less power (ICE 22/43W into 8/4 ohms)
Since I tend to keep my gear for very long, I like AI-503 more because of pre-outs, so if I decide later to add more power, I can use it as a preamplifier.
On the other hand, currently I'm using fairly low sensitive B&W686 (85ish DB) and don't plan buying new speakers immediately. Would 22 wats be enough for them?
Or should I go with Ax-505, which has more power, so I wouldn't probably need additional power in the foreseeable future.
Btw. I live in apartment and have small kids so I mostly listen at moderate levels.
AX-505
AI-503
