- Thread Starter
- #121
Sure, I will make sure that you will test something soon.Already got the SMPS2000R for testing our SE800, hope we can try your SMPS next time![]()
Hi, passive cooling is enough for SE800 modules.Hi all,
Following this thread with interest.
What sort of cooling would I need for 7 or 9 of the SE800 modules in a single enclosure?
The application is my theatre. Currently running 2 Crown CTS 4200 and a Samson S720 in a 7.2 configuration.
Great, thanksHi, passive cooling is enough for SE800 modules.
Is this true of the latest FB-360 modules? If so please say more about the harmonic profile you target.Inductors for SylphAudio's class-d modules were not only selected for the THD+N score, but also for harmonic profiles.
I think I selected it for THD+N for D400M P05 and FB360 when I tested on the variety of inductor samples, the ones installed are better than the coilcraft 10uH AGP/VER2923. (on par with coilcraft 6.8uH ones)Is this true of the latest FB-360 modules? If so please say more about the harmonic profile you target.
@daniboun Hello, I have some questions if you could have some time for me. But I can't DM you, can you DM please ?
Hi, we've already sent the FB360 and FB100 to ASR for review a few months ago. Although they use SpeakOn connectors, which Amir mentioned he doesn't have an optimal setup for yet (he uses his SpeakOn wires on high-power PA amplifiers). FB360 and FB100 have a deeper PFFB configuration, so we expect them to perform better than the competition. FB100 has been upgraded with all OPA1612 opamps, while the FB360 still uses a mix of OPA1612 and OPA1602. We've resent the upgraded all-OPA1612 module 2 months later, so Amir has to swap out the newly upgraded FB100 module over the old one (comparing old vs. new module would be interesting though).But I'm looking for modules with better Power VS Distortion, because the increase of distortion in higher frequencies scares me a little bit and might not match the quality of my speakers
The 3 modules needs to be able to produce 2x60W peak 8Ohm which is not the case with the FB100 sadly, might be only 40 clean watts? but I can get away with that
Is there anything that could make me want to go for 3 x FB100 (80Hz-20kHz) and 1 x FB360 (20Hz-80Hz) instead ?
I lack of reliability + performance data and user experience
I'm planning to use MORNSUN LOF550-20Bxx units for your information
The power supply definitely affects high-frequency performance. I used two different batches of Topping's stock PSUs for the PA5, and the difference is clear.As for the choice of power supply for TPA325x, my opinion is that the PSU affects the smoothness of the highs. Low registers, not that much unless the PSU is horribly substandard.
