Hi, I know I have read something about this before, but I can't remember the exact terminology for this. So googling didn't help much.
In short, my system sounds great, but I only get the right subwoofer level at the volume I calibrate at. If I play at a lower volume, the sub disappears, and at higher volumes it overpowers the monitors.
My setup is Neuman KH-80 monitors + Kali WS 6.2 sub
At the moment it is run through a Topping DX5, with sub passthrough handling the crossover. I am about to add my old MiniDSP DDRC-24 to the mix, probably removing the Topping DAC.
I set my monitors' output level to 94 dB, as anything higher resulted in an annoying hiss, and I suspect this is the reason for them to have a less steep volume curve than the sub has. So how can I make my sub follow a similar curve so I can have one calibration working for both high and low volume? Would like to figure this out before I start calibrating anew (UMIK-1/REW/Dirac)
