Streamer vs BT
gallionetech
South Florida
Hey all,
I was wondering if there is a downside to using Bluetooth instead of a Streamer?
Also if i did go with a streamer, any issue with a Raspberry Pi plugged into USB of a Topping D90SE?
Thanks in advance!
AudiOhm
London, Ontario, Canada
A streamer gets the music, Bluetooth transmits it to your wireless device, not sure what you want to know...
Ohms
gallionetech
gallionetech
South Florida
Ohms
Basically if there is any downside of using BT, will there be a performance loss, etc.
AudiOhm
You are trying to compare apples to oranges.
You cannot compare Streaming and Bluetooth...
Ohms
gallionetech
gallionetech
South Florida
Ohms
@AudiOhm Im new to the audio world and other than the fact that Bt is transmitting to the device what is the difference? I'm genuinely unsure and want to make the right choice for my setup. Thank you
MaxwellsEq
Bluetooth is a "wire replacement" technology. This means you can have a mouse without a wire (alternative approaches are available as well); headphones without wires; music players and phones without wires; portable speakers without wires. Historically, Bluetooth is not as good as a wire in terms of sound quality, but recently newer codecs (a codec converts the sound to a signal which can pass over Bluetooth) such as Sony's LDAC have emerged which are much better. Bluetooth has got absolutely nothing to do with "streaming".
A streamer plays music into your HiFi from a "file". The file may be on your laptop, a NAS or via a service such as Spotify, Amazon Music, Deezer etc.
Most high quality streamer installations don't use Bluetooth. For example, I use a streamer plugged into my DAC which gets files from my NAS via my private IP installation. There is no Bluetooth involved.
You can use Bluetooth to replace a wire in a streamer installation. Historically, this has resulted in poorer sound quality, but newer codecs exist which make it a viable approach.
gallionetech
gallionetech
South Florida
Makes total sense. I setup a Volumio RBP setup and I see the other benefits such as built in EQ, etc.
Thank you for your detailed answer @MaxwellsEq!
