That's really bad...Depending on your budget, this (everything you will ever need in one box):
https://www.minidsp.com/products/streaming-hd-series/shd-power
or this (Bluetooth only, in stock in April):
https://hifi-express.com/collection...jie-a30-digital-power-amplifier#collapse-tab1
No active speakers, need poweramp inside.Active speakers or not?
This ain't stellar either but it's cupple steps up.
https://www.denon.com/shop/networksystem/ceoln10
Amp's about 86 dB SINAD thanks to second harmonic, software part ain't great and DAC is from ESS 32 family.
Havent seen that one. Was thinking of upgrading my avr to the 3700 and thougth of a 2-channel that would perform better, instead.That's really bad...
Mini DSP.Are you commenting over the Loxje or the MiniDSP?
Mini DSP.
Thats a good point. Gone from just listen to just trust measurements...I think the MiniDSP with Dirac would defecate over the Benchmark AHB2 in pretty much every real world.
try to look past the SINAD obsession.
I am but old Burr DAC there says to me no thanks. Denon is at least there regarding deacent mid LPS speakers tho it doesn't have much power.I think the MiniDSP with Dirac would defecate over the Benchmark AHB2 in pretty much every real world.
Sorry 108 dB SINAD where? Make that 99% content.If 108 SINAD is too low for you then this forum has really spoiled you! hahahaha
Specially considering 90% of content is CD quality so 96 is the theoretical maximum
Quite don't believe that regarding DAC, do you have measurements?the DAC of the MiniDSP SHD Power.
90 dB SINAD for the power amplifier.
If it's 90/90 dB than congrats it's better than Denon (as there's no use of DAC being better than power amp nor do I see much of a benefit of DSD support on ESS lacking on Burr).
Found it it's 88 dB regarding power out and it's better than Denon (two dB) congratulations.yes it's been measured by Amir on this forum.
