Worth looking at the possibility of ground loops - especially involving the AVR and Crown amps - possibly also including one or more of your sources.
What is the cable interconnect length between ARV and Crown amp?
The cable is a low quality, 4 feet RCA.
Yeah, this is plausible. There would be signal going through the circuitry of both the AVR and power amp for the sound to reach the center spk. This is somewhat unlikely. Grounding problems more plausible.
--It would be fun to see if the leak to center gets worse or better with
A) Adjusting gain up and down on preamp with disconnected power amp or
B) Adjusting gain up and down on preamp with power amp on but discinnected speakers or
C) Adjusting gain up and down with all connected as usual.
Questions:
A) disconnected Crown, right? Just making sure because I have two power amps in the setup.
B) OK.
C) in the preamp or in the crown amp powering the center?
I will run these tests tomorrow.
Thank you all for the support.
As I said in a prvious post, there is a ground loop. It gets quite annoying when ny PC is turned on. And I can hear the noise coming from
The center channel when music is low and in stereo (not coming from the center).
