dasdoing
I have been strugling with this for some months now, and though it was a problem with my install. now that I tried the snap install that create totaly fresh folders and have the same problem I realized that the Linux app is totaly "broken".
can anybody change loudness normalization setting?
my settings will have no effect whatsover.it is fixed at meassured -11 LUFS, which coresponds to the "loud" setting. this means even paying I am only able to get music in limited dynamic range.
speaking of quality: the quality setting doesn't seam to have any effect, too.
there is no change in the "prefs" file whatsover.
we are probably restricted to the "normal" quality setting even PAYING for higher quality.
I suggest you guys to open the prefs file in ~/.config/spotify and look for any changes in it when you change those settings.
Also who ever knows how to, meassure the loudness level of the output. one tool which does this is http://kokkinizita.linuxaudio.org/linuxaudio/ebumeter-doc/quickguide.html
