Schiit Audio: Audio Products Made in USA
Interesting seeing single-ended connections.. guess they want to use the same form factor as Aegir. 30w for 5 channel??
Power Output:
2 channels, 8 Ohms: 30W RMS per channel
2 channels, 4 Ohms: 50W RMS per channel
5 channels, 8 ohms: 20W RMS per channel
5 channels, 4 ohms: 30W RMS per channel
Frequency Response: 20Hz-20Khz, +/-0.03db, 3Hz-250KHz, +/-3dB
THD: <0.008%, 20Hz-20KHz, at 100W RMS into 8 ohms
IMD: <0.009%, CCIR, at 100W RMS into 8 ohms
SNR: >118dB, A-weighted, referenced to full output
Damping Factor: >100 into 8 ohms, 20-20kHz
Gain: 10 (20dB)
Input Sensitivity: AKA Rated Output (Vrms)/Rated Gain. Or, 14.3V/10. You do the math.
Input Impedance: 22k ohms SE
Crosstalk: >85dB, 20-20kHz
Inputs: RCA jacks x 5
12V trigger: yes
Topology: current feedback, fully complementary, all 2SC/2SA BJT, no capacitors in the signal path
Oversight: microprocessor-controlled monitoring and management of critical operational points, with with relay shut-down for overcurrent, thermal, and other faults
Power Supply: 600VA toroidal transformer with 66,000uF filter capacitance, plus boosted, regulated supply to input, voltage gain and driver stages, plus separate, isolated and regulated rails for microprocessor management
Power Consumption: 300W maximum
Size: 9” x 13” x 3.875”
Weight: 22 lbs
