I had typed a nice post for you.. but you're not worth the time. I'd advise you to actually contribute something instead of nagging.
As for the A/B testing.
Have a good day with your hobby of knowing it all and finding posts to nag on.
OK, it goes this way:
1. My memory may be wrong. I saw Amir was testing stock SMSP against a lab power supply? Lab power supplies are mostly SMPS as well.
2. Components in DX3 are fed by DC-DC converters, 54331. 54331 works at the frequency 750KHz. This means it needs current feed around 750KHz interval.
3. 750KHz is a fairly high frequency for most power supply. To meet 54331's current demand, you need good capacitors to feed the current.
4. The capacitor needs to have enough current reserve and most importantly, it will work well at 750KHz.
5. This capacitor in DX3 is not only fairly small - 100uf. And a no brand name one, who knows how it performs at 750KHz?
6. The stock power supply is small. It may not have any big capacitor at the output side to feed current to DX3.
7. Mean well SMPS is better cause at least it has decent output capacitors.
8. Power supply's job is to feed this capacitor on time. The easiest indicator is the load regulation performance of the power supply. It's about how well the regulator can keep the capacitors current reserve at a consistent level. Linear power supply is better here. Still, linear power supply works in a frequency much lower than 750KHz. Again, you solve the problem by putting enough capacitors at the output side of the power supply. In this case, solid polymer caps are better for their excellent high frequency performance.
9. Good power system design engineering is important. Good engineering comes before good measurements because measurements may not cover certain important performance aspects. Sure, there are power system test means. AP is not for testing power system.
10. Many people have misunderstanding on bass performance. Take strong and fast drum beats as an example, the combination of harmonies may look more like square waves (even after the brick wall 22KHz filter on the recording device). I.e. There are still mid high frequency components in a drum beat. Square waves have a huge demand on the power supply though we do not have any standardized means to test square waves. People have been long testing amps with square waves by observing the result on scope, however.
11. Another thing is speakers usually have lower impedance at low frequencies. This means they will need more current at low frequencies.
12. Hence after power supply upgrade, most people will hear improvements on mid bass right way.
13. So some catches with AP tests - a) AP can only see part of the power systems performance. b) Have you tested the right SMPS against the right LPS? c) AP may have shown the differences yet they are interpreted as of little significance and ignored.
