Are you afraid that the reverse current, in our case the current from the potential of 100 mV, can damage 4493? Can we install diodes instead of capacitors to prevent this?
I'd rather have the hottest girl, but I can't afford such an expense, I'm affraid.
I measured the AK4490 surface temperature with a (K-Type) thermocouple connected to a digital multimeter.
DAC looks like this:
I've got parts rolling in.
Kemet KO-CAP 100uf that fit perfectly for the DAC output.
Some transformers to play with
More caps coming in. I follow up to Finnybear's advice. Still waiting for the polymer radials and the Panasonics for the digital input.
It's spring festival here.. I tried to persuade many shops to still send me some with the last open shipping company. but it's difficult
Re tube amps:
SE transformers have gapped cores to be able handle DC.
Push-pull transformers operate in full diff mode, with same voltage at two ends of the winding, resulting in net zero voltage across transformer.
Small signal transformers will saturate with as little as 40mV offset.
You really need to know what you're talking about when dishing out advice. I'm not the one who's confused. Your post on mono mode is simply wrong too. Even voltage out DACs have theoretical benefits when used properly. Go read a few datasheets and application notes to refresh your knowledge please. Not trying to be rude, but you're simply wrong on a number of things.
Yea babe, we have the music now
My God! What are you doing here? LOL
Actually you do not need bi-polar here. Silmic will work just fine.
LOL. Then probably you should get a black one instead? Black is hot yet runs cool.
Obviously you have the magic to run things hotter than they should have been.
The ones in the photo are 10k:10k Jensen clones. I've got a pair even better quality coming in. I got the taobao recommendation from Pavel a bit earlier in this thread. The shop owner is really cool ! And delivers quality and service. He started out cloning buy now his own versions are better quality and after spring festival he has some new products coming. I'll give them a swing.What kind of transformers are those?
Yes, I am also well acquainted with this manufacturer. I bought more than 60 transformers from him. But you bought the wrong model! jensen clone sounds bad. you had to buy exactly what I indicated. This model is called R3.The ones in the photo are 10k:10k Jensen clones.
There's something seriously wrong. I encountered various issue as well.Well a mean well 15V 1.66A didn't help, the device shut down in the middle of the game. Was keeping it on A-C too. So this is not the solution.
Mine isnt dead, it just shut down, i turned it back on with remote after.
It was necessary after soldering four capacitors and four shunts to try. Now it is too late, do not otpaivat back this hedgehog. And on power 1612 what capacitors put? We must also pick up a good ceramic capacitor. In datashit on 1612 write:Yea babe, we have the music now
Unfortunately that I do have the datasheet for this permalloy transformer. It can easily withstand 10mA input/output current.
Now, just take 4493 full swing output at 5V, the transformer has a 10K impedance : 5V / 10K = 0.5mA.
Once again, you are basically wrong.
10k impedance only applies to AC currents. DC currents are determined by the winding DCR, not the impedance. You do know the difference between impedance and resistance, don't you? If you can confuse these two, I'm not any of your advice is sensible.
Since you claim to have 'Designed' SET amplifiers (and I'm being generous and as courteous as possible here), you will know the transformer is different from a PP transformer. They are built to handle a large amount of DC current without saturating, by gapping the core. This also leads to needing a lot more copper and iron for the same amount of output power, which is why SE transformers are much heavier than PP ones. But you knew this already since you 'designed' such an amp, yes?
To go back to the example here, I am looking at a Lundahl 1690 datasheet that states primary DCR is 150 ohms. With 3.3V across the winding, you will have 20mA of steady state current. At 1.65V as per your 'advice' of omitting cap and connecting single ended DAC output directly to transformer winding, the core is already saturated at 10mA. All I/O application datasheets will tell you that DC current is a no-no as even if a small amount of current reduced output capability and increases distortion.
