See MattG's comment on page 102...It would be really good if someone who experiences shutdown problem more often could test with some decent, aftermarket power supply. Mean well for instance. I would do it myself but self shutdown happened to me twice in 2 months, both solved by powering on.
For the record, I have everything connected to APC back-ups at all times.
Thanks, missed this. Disappointing.See MattG's comment on page 102...
You can benefit more in sound quality if you replace 8 conventional tantalum capacitors with Kemet KO-CAP.
Like previous comment said, you'll probably get more benefit from replacing caps rather than replacing opamps, anyway it will be very interesting to see results!I opened it up and decided to replace the SOP8 socket with a swappable DIP8 socket. But obviously there is not much space and I'll be trying to squeeze in a SPARKOSLABS SS3602 discrete opamps instead of the standard (already good) OPA1612 opamp.
I posted last week, doing this exact test:
I came in to my office this morning with the unit in sleep mode: powered on, but only a single illuminated dot on the LCD display, and no sound. So it only made it about a week with the alternate power supply (Meanwell GS90A15-P1M).
So per Topping's email above, it appears to be a problem with the power circuit logic. Hopefully this is firmware fixable!
Edit: I sent Topping an email about this.
I hate to say it but the moment I noticed you said you were going to install a SOP8 to DIP8 converter to install a discrete opamp in your earlier comments, I knew this wasn't going to end well. I mean no disrespect but could the expense you have ended up with by taking this path ever be worth the cost when we're talking about a sub-£200 all in one DAC/headphone amplifier, with more than a few buggy issues and according to the reports on here its long term reliability is questionable?I opened it up and decided to replace the SOP8 socket with a swappable DIP8 socket. But obviously there is not much space and I'll be trying to squeeze in a SPARKOSLABS SS3602 discrete opamps instead of the standard (already good) OPA1612 opamp.
Comparing the DX3 Pro to my LKS ES9018 (tuned with jefet class A I/V stage and high-end audio grade components)
I notice that the DX3 has more detail and more forwards mids which I like. But it's lacking in soundstage and the lower frequencies are a bit underwhelming. I think this is mainly because chip flavor and not so much due to output stage differences thought. Still I want to try to make an upgrade to the OPA1612 to see if I can open up the soundstage a bit and get that bass a bit more defined.
First need to figure out how to get it all to fit in that small space and convert SOP8 to DIP8
OPTIONS!
Lowest possible option while still swappable. I might solder it in completely later if I like the change.
Barely fits... Like I said soldering it in completely will be the safer thing to do but first I need to roll some!
Costs are already getting out of hand since I was tired last night and thought I could quickly solder out the SOP8 opamp to solder in the DIP8 socket.... but my eyes couldn't keep up at that time and I broke the coper tracks on the board and it's properly useless now. So I contacted the Topping factory in Shenzen and let them send me a new board for 800 RMB (€100 I think). Next to that I ordered a completely new unit to compare with. I'll modify the replacement board and keep the new unit original.
The Opamp is the most expensive out there at 690 RMB (€80) it's pure overkill for a device that cost me €140 at first, but I have a feeling that this device might be able to sound really bigger than what's its capable of originally. So let's just go for it and do it right this time.
In about 2 days I'll be able to report back after all my orders came in to finish the project.
It is possible it is caused bynbug in Topping's implementation of the auto-standby mode.
To isolate the problem. Is your device running at auto-standby mode? Could you please turn it off and see if the problem continues?
Whats "A-0" and "A-C" when pressing Auto on the remote? I dont even understand their garbage manual.
Which one disables auto-standby?
I say this as someone that used to spend a lot of time trying to out think designers by pursuing perpetual upgrades, before learning the hard way that 99% of the time, the simplest and most routes usually made the most worthwhile changes.
I plan to:Let's discuss possible mods... I hope to find some people that are willing to get their hands dirty
As you can work in Chinese, there is something you could do that would be rather useful if you can explain it to Topping. On the remote for my Topping DX7s there is (IMHO) an obvious error of logic that should be changed but I fear that it will need someone fluent in Chinese to explain. Here we go....I read the manual in both English and Chinese and here is my understanding
Exactly the same behavior in DX3 Pro. I even proposed solution for fixed line-out (separate settings available via settings mode in DX3 Pro) but there could be a problem to fix it via firmware. I believe, they'll manage itAs you can work in Chinese, there is something you could do that would be rather useful if you can explain it to Topping. On the remote for my Topping DX7s there is (IMHO) an obvious error of logic that should be changed but I fear that it will need someone fluent in Chinese to explain. Here we go....
Buttons such as FIR (filter selection) and AUTO (auto power ON/OFF) serve as both interrogation [tell me what mode am I currently using?] and change (by pressing the button again). Problem is, the first press changes the state and it is necessary to press the button – five further times in the case of FIR – to get back to where you want to be. Logically, the first press should be just interrogation. After a couple of seconds, the display should return to its default state and NOTHING should have changed. It is only a second press – before the display returns to its default state – that should cause the function to change.
Another logical fault is the ease with which DAC mode can be selected. This is the mode in which the volume control is bypassed and the unattenuated DAC output level is sent to the power amp. This has the potential to be harmful (and possibly, dangerous to hearing). The selection of that mode really needs a safeguard involving a second press of a different button ( to safeguard against accidentally double-pressing a single button).
If you could explain the above to Topping, you would be doing their business, and us, a great favor
