Revel C208 Distortion/Harshness
ripziro
So here’s my setup: denon x3700h (preamp rca out, audyssey xt32 flat) -> Monoprice Monolith 5x200 (rca in banana plugs out) -> revel c208 (Tweeter Switch set to 0db)
Playing movies on Apple TV 4K I notice a bit of distortion/crackling come from the revel c208 — sometimes and usually for short periods of time. It’s something I need to really squint/focus to hear, 90% of the time I don’t notice any problems. But when I do hear it, I think the effect is more obvious at higher volumes.
Has anyone experienced something like this with the revel c208 before? Am I likely to have a defective unit?
Also I may have flipped the tweeter level switch while audio was playing a few times before I realized the manual cautions against this — is this dangerous/likely to have damaged the tweeter?
Dj7675
Edit... Whoops I see it is a C208 and not an F208.... But the same applies regarding Audyssey flat... It isn't out of the realm of possibility for there to be a problem with the speaker though. I am using 3 C208's below my screen and I had one new one shipped new that had an issue. If you have REW, you can take a measurment of the speaker from 3 feet or so to see what the response looks like and/or measure distortion.
Before jumping to a defective tweeter... do you have the $20 audyssey app? I would first limit correction to 300-500hz. The F208 is a great measuring speaker. Audyssey flat will take your in room response from something like the estimated in room response to a flat line. It most likely will sound harsh/bright. It would be a shame to take such a great speaker and have Audyssey flat ruin it. Do give it a try. Could simply be audyssey flat ruinning it...
Revel F208 Twoer Speaker Spinorama CEA2034 Predicted In-room Response  frequency audio measure...png
R
ripziro
Huh, never realized it was recommended to limit audyssey to 500hz. Does that mean once I limit it and send it to my receiver I should use the "Reference" curve?
Are there any other gotchas with room-correction I that could play a role here?
Dj7675
I would say a very large percentage of people here would tell you not to use Audyssey flat. Whether or not you EQ the full range is a different question. With the Audyssey app, you can either limit the range of correction, or you can EQ it to a custom room curve. With that speaker I would try it without EQ over 500hz first. It should change how it sounds quite a bit. After that you might try some type of harman curve with a downward slope and see what you like better. When you use the app, you do need to use the reference curve and not flat.
R
ripziro
Cutting off eq at 500hz and 300hz doesn't quite seem to do it, but I tried listening to some of the same sources on a different device and I noticed similar distortion in the exact same areas that I notice it on the revel c208. So it seems that the source audio for the show I'm watching might have some anomalies, which is quite surprising. I think the revel c208 just makes those anomalies more notice-able.
