Request for MoFi SourcePoint 888 & Caladan OB
grandpixel
Would like MoFi SourcePoint 888 to be measured / reviewed and added to database.
Also Caladan OB speakers.
I see. I don't see them in the review index on the site.
Right, they were reviews on Erin's Audio Corner. He also has a Klippel machine and provides most (though not all) of the same data that Amir does in his reviews. I prefer Amir's reviews, but ultimately if Erin has reviewed it there's not much need for Amir to largely reproduce the same data here. If you want to compare it against others, use the Spinorama database staticV3 linked to.
Indeed, not much about it not to like, asides from the price.
There are very few reviews of OBs. Yes, there are very few OBs - but they have qualities often partly misunderstood
as the physics is different and more involved. And even fewer than the number of reviews. described properly. Only imo by SL and in a fairly technical way
Anyhow, Caladans are not too expensive, at USD 3500 is 30% less than the MoFi 888s - but similar amount of innovation and size
Great suggestion. Maybe someone eg Amir should contact Caladan.
This is an in room REW sweep taken at the listening position in my workshop where the recently received Caladans are currently breaking in. Am sure a Klippel system would measure differently since the room effects are removed.
Clayton Shaw Acoustics Lab can't even fill existing customer orders in a timely fashion. Mine showed up 9 months after the promised ship date and were missing the bag of hardware to mount the GAIA III feet. That bag of bolts showed up today, 10 days later. In the mean time I stole the bolts out of a set of GAIA III feet on another speaker and went to Lowe's and bought the required 1/4x20 bolts for the triangulated braces.
