Recording quality of Motu mk5 vs M4
Blumlein 88
Okay, so I need the opposite of what you would see in the headphone amp example? In fact a large input impedance? That's what rectifies this ribbon caveat? (Keep in mind, I am completely when it comes to how mics behave and how ADCs, or I should say mic preamps are expected to work from a performance point of view).
Yes a larger impedance is better for ribbons, but pretty much a non-factor with other microphones.
Just one example a Focusrite ISA One microphone preamp has selectable input impedance values of 1400, 2400 and 6800 ohms.
Here is an explanation on the needs of ribbon microphones.
Reactions: Tks
AnalogSteph
.de
It's actually much the same, just the roles of source and load are obviously reversed on an input, and it's source impedance that is variable rather than load impedance. Either way you want Zload >> Zsource. A typical case of variable source impedance on a headphone output would be capacitor coupling. You may remember that portable devices went DC-coupled simply because coupling caps suitable for 32 or even 16 ohm loads became rather impractically large if you insisted on a sub-20 Hz f3.
In case of typical ribbons it is the output transformer that is responsible for the impedance variation. The actual mic element generally is <1 ohms and would be a very poor match for common mic inputs without some help. That being said, you can also go with an active ribbon mic which generally presents a low and flat source impedance. These may still be using a transformer internally, otherwise you end up with the need for a very low Rbb' transistor grave supplied by a DC/DC.
BTW, it is quite well-known that dynamic mics will react to input impedance as well. As they tend to have their resonances with corresponding impedance peaks in the bass and the ultrasonic range, an input impedance close to 1 kOhm tends to make them sound duller than 3 or even 10 kOhms. This is documented for the SM 7B for example... I guess it being fairly neutral makes these effects more perceptible. (It's like detecting minute color shifts on a calibrated monitor vs. one with a white point that's way out there.)
Reactions: Tks
Tks
Did some googling on some of the portions where I got hung up, but thanks Steph, for putting it into more clarity.
Archon43
I had this question as well when I got M4, because I chose M4 for its nice looking figures, and I naively believed that the better figures it have the better sound quality it shows. I was absolute wrong, the preamp sounds a little bit brittle and edgy but stays clean in general. So the M4 gave me a good lesson about sound quality and parameter.
I have no idea what you are talking about.
I just had 4 audio interfaces to directly compare and the M4 sounds awesome with my Rode PodMic dynamic mic (which is a $99.99 wonder and is a bit power hungry). I prefer the sound of this with both recording and audio output as opposed to:
-Focusrite 18i20 3rd Gen $549.00
-Audient ID14 Mk2 $300.00
-Audient EVO 8 $200.00
-M-Audio Air 192/4 $119.99
This is using them as the sound out and input device, as well as using my Topping E50 as the sound output device.
It sounds more dynamic and better balanced than any of these. I am not hearing "brittle, edgy sound" at all.
Sure, maybe if you have boutique mic preamps sitting around to compare it, it would come up short (as would any audio interface, even high end ones). You are mentioning mic preamps that cost more than this audio interface, so I would expect they would sound better!
Saying you do not like the sound is fine, saying it sounds, "Bad" is a poor choice of words, and even based on specs, makes no sense. I expected the Audient ID14 MK2 would sound better using the same mics and the built-in preamps, considering Audient's pedigree. It was not the case, the M4 sounds better both recording the mic and the output (using it as the computer's main sound device). This is likely due to using ESS as the DAC.
My voice (recorded with Audacity and no special settings besides setting the recording to mono) sounds exactly as in person and really makes my Rode dynamic mic sound it's best. I am not hearing any audio issues, sound quality issues, it sounds really good and I am playing it through a Denon x3500 receiver with Polk Audio Signature S55 towers and a complete Signature ATMOS setup with a RSL Speedwoofer 10S.
You must either have a problem with your setup, or a defective unit. The only other thing that would make sense is if you are using a hard to drive ribbon microphone with no cloudlifter, then I can see this having trouble with sounding good in that scenario. You are going to run into issues with any audio interface with something like that!
There is absolutely no issue running my Rode PodMic, Audio Technica ATK2100, or Marantz MPM-1000 mics with this MOTU M4. All three sound good, but the PodMic sounds the best of the three easily. It is also the hardest to drive of the three.
cajadas
I agree. Had an Audient ID14 MK2, mainly for testing purpose, before buying M4, and MOTU's DA sounds better. I can't describe the differences now after a year or so, but they were noticeable and made me decide for the M4 without a second thought. I was trying to get as close as possible to an Antelope Audio Discrete 4 SC I had in terms of output quality (DA, clocking, implementation) and the M4 is it. No Antelope, but gets the job done and still sounds amazing for the price. No schiit under 500€ interface. I have tried them all.
