Quick and dirty room mode correction
suttondesign
Bellingham, WA
Hi everyone. I have comments and a question. I've moved for several months into an apartment near where I'm building a new home, and I've done a quick-and-dirty A/V setup in the small apartment living room using Dutch & Dutch 8C's, which let me avoid lots of boxes -- the Mac Mini server tucks behind the TV, and all that peeks out is a Topping D30 Pro.
Knowing there would be one or two dominant modes below 100hz at the general listening position, I used well-known tracks with thwacks and thumps at various low frequencies. I also used a mode calculation spreadsheet to estimate where modes might be. I was able to quickly narrow down the prime offender at 45hz -- and it's horrendous. A steep notch made it disappear, while notching at 40hz or 50hz was not as effective. So I've got the right number!
Since I use Roon, I have good parametric EQ available on the fly. I've provisionally settled at a Q of 10.
Question: Can anyone suggest a preferred Q or octave fraction for bass modes? I don't have access to my EQ mic and software for months, so I've got to get by on guesstimates.
Oh, and BTW, the feathery smoothness of the Dutch 8C above 200hz!
AdamG
Moderator
Reality
In a small room (assuming small apartment size room), it can be easier and cheaper to move your seating position out of the dip and or move the speakers closer to the MLP. Just a suggestion that many, not saying you, overlook.
AwesomeSauce2015
Main Listening Position
Less speaker->MLP distance means more direct sound which means less room effect...
Although very small rooms have their own issues. Room correction isn't really a 1 and done thing. You have to correct specifically for your setup.
I mean, my stereo is setup in a micro-sized room. I literally just don't try to correct the bass as it's way easier so just turn it down, and by turning it down the neighbors don't hate me as much :) And considering my speakers don't have much bass to begin with, it doesn't really impact the sound lol.
But that's just my preferred solution. Your solution will be different as you probably want to utilize the bass capabilities of your speakers.
BrokenEnglishGuy
Oh lol,
I have a mid-size floorstanding in my small room(KEF R7), fun thing is i got +9dB in 88hz~, even the in-wall tv in my bedroom have '' impressive bass '' giving all the bass enhancement that I got from my small size room 3x3 mts.
That being said, i got some cancelation in the mid-bass, i don't longer have my speaker but as i can remember, i had only 1 position that i not cancel too much by itself. My plan was buy a umik-1..
I did some very bad quality measurements and I use a parametric EQ by ear. It took me 3 months to learn of my bedroom sounds like, but i dont have speakers for now..
MarkS
Can't do better than a guesstimate without measurements. The Q depends on stuff like how absorptive the surfaces are.
Joachim Herbert
Munich, Germany
Take measurements with REW, generate filters and export them to 8C.
Martijn Mensink
Industry Insider
Yes, please! I'm sure it will make a big difference.
Reactions: GDK
S
suttondesign
Bellingham, WA
Joachim Herbert
Munich, Germany
Did not read thoroughly. No "fix" by guessing, I'm afraid.
bluefuzz
As I mentioned in my posting, I cannot access my mic setup while I am living in the apt, hence the need to fix things as best as I can without.
Don't you have mobile phone? There are plenty of cheap apps that can measure a frequency sweep well enough to make a reasonable correction. I can recommend 'FFT' and other apps by Studio Six Digital.
S
suttondesign
Bellingham, WA
news to me! i will check it out.
