I'm a total beginner and after about 15 years without any option to listen to music except headphones or some tiny Bluetooth speakers I went with this neat solution below. Its good enough to sound pleasant to my ears and perfectly fits my current tiny room of <20 square meters.
I would just like to get a better understanding of all that is involved with DACs, amps and speakers. I've read a lot online, but most info is way too technical, with lots of formulas and stuff. I just want to get a better basic understanding not become a professional audio engineer if you get what I mean.
I am currently using a RPI zero w with a MiniBoss DAC PCM5122 32bit 384kHz and a Volt+ AMP + a stepped attenuator to power a pair of Monitor Audio Bronze 100 speakers.
The amp can deliver 2x50W @4Ohm while the speakers are rated at 8@ so from my basic understanding that cuts the power in half to 25W (Yes I know those are maximal theoretical values, right?)
So when I stream audio to this device, I can listen at low volume and at a high enough volume for the room size. I know the amp is underpowered for the speakers, but it works for me. I'm wondering why I see a base power consumption of 3.1W when the amp is idling (nothing is playing) and up to 4.2W when playing at about 80% of the volume (can't go higher or the neighbours will complain). The device I used to measure plugs in between the power source and the plug and its accurate (tested with a lamp with a 60W bulb, and it showed 60.1W).
So here are my first two questions:
- If 2x50W @4Ohm translate to 2x25W @8Ohm, and I'm listening at about 80% (20W) why do I only measure 4.2W being drawn from the plug?
- If the amp says 2x50W, why does it only come with a 19V 3.15Amp (60W) PSU? Wouldn't it need a 100W PSU to deliver 2x50W?
