Question about importing Amir's filters: Rephase into DSP for Volumio
xarkkon
So Amir's latest Sony post, sweetchaos's PEQ compilation, and doodski's EQ software compilation has finally gotten me down to figuring out EQ for my Volumio/Hifiberry headphone setup.
I'm absolutely clueless at all of this and am trying to figure things out as I go along. Can I check if i'm doing things correctly by doing the following:
1. No need to create any measurements or parameters from REW / Equal APO etc, I can just rely on rephase entirely since the filter settings are all available here
2. Preamp gain goes into General > Output settings
3. Filter settings go into Paragraphic Gain EQ, where I can choose 1 single "EQ type" to apply across to all bands
4. I can then click generate to create the impulse file to put into my volumio DSP
Is the above correct?
Also, can rephase allow me some bands with shelving and others with peak/dip? I can't seem to find any such option as choosing shelving seems to apply to everything.
Thanks in advance!
Thanks in advance!
1. Correct
2. Correct
3. Almost correct. You can have multiple 'banks'. This allows you to add in a mix of filter types ie low shelf + high shelf etc. Each bank has to be the same type
4. Correct. Generate a txt file and just dump it in the correct directory.
1. Correct
2. Correct
Awesome! Thank you so much @rkbates! Silly me didn't realise what the banks were.
Can't wait to play with this!
