I'm working my way through the settings on a new Hifi Rose RS150B and I'm a little confused while trying to match the Rose's analog output voltage (adjustable) to the max input voltage on my Yamaha A-S2200 (integrated amp) balanced input. The spec from Yamaha reads like this: Input Sensitivity - [1 kHz, 100 W/8 ohms] PHONO MC: 150 uVrms/50 ohms, PHONO MM: 3.5 mVrms/47 kohms, CD, etc.: 200 mVrms/47 kohms, MAIN IN: 1 Vrms/47 kohms, BAL: 200 mVrms/100 kohms. The way I understand this information, the Yamaha wants 200 mVrms at its balanced input, but will handle 1Vrms at its unbalanced input. Is this correct? Can someone explain the gap in the two voltages?
Adding to my confusion, I looked up the spec on the Yamaha CD-S2100 which is intended to pair with my AS2200 thinking I could just set the Rose at the CD player's output voltage. The spec for the CD player's output level reads: 2 +/- 0.3 V (1 kHz, 0 dB). So if I'm reading that right, Yamaha's own CD player outputs twice the voltage wanted by the AS2200? There's no distinction for balanced/unbalanced in the CD player specs.
The Rose can output up to 9Vrms at XLR.
Hoping to better understand this.
