Hello all!
First time poster here. Been trying to be a cheapskate for an audio setup to attach to my (cheap) TV via toslink which is connected to the latest Chromecast w/remote. At first I tried a set of powered Rockville HD5 which had most of the features I wanted, and while I considered the sound quality acceptable, both bluetooth connectivity and the included remote were a flaky mess, so those got sent back. Then I decided to get the Topping E30 to connect to my 8" Event 20/20BAS powered monitors that have been sitting unused for years, just to immediately find that something sounded off. As it turns out, one of the tweeters stopped working. I opened it up and investigated the amp PCB, but didn't find anything immediately wrong. I then checked the tweeter resistance and it was open. Strange. It worked the last time I used them. Well, finding a replacement tweeter is a somewhat expensive proposition, and even if I got one, I still think the amp is suspect. So I decided to instead go with a Topping MX3 due to the generally favorable reviews (I'm still trying to be cheap), and a set of Neumi BS5 speakers after reading Erin's review (used the affiliate link too ). While I was at it, I also got some foam isolation wedges to cant them upwards since I have little choice but to put them on my TV stand which sets them too low.
Anywho, on to the reason for this post. While normally I don't listen to music or TV very loud or require much bass, it dawned on me that for those times I do want those things, maybe I could use my remaining functional 20/20BAS monitor. And since the "sub" output on the MX3 isn't low-pass filtered, I thought that I could use the monitor as a center channel of sorts that will also help with freqs lower than what the BS5s are happy with. Does this sound like a silly idea?
Also, it might seem stupid, but one of the reasons I wanted to go with Topping is that it is supported by the Chromecast remote, which is the only remote I want to use. Truth be told, if Edifer was supported (and probably will be eventually), then I would have just got a set with toslink and BT and called it a day. But I suspect the MX3 + BS5s will be a better sounding and more flexible setup. At least I hope so, considering I'm in about +$100 over a suitable set of Edifers.
