- Thread Starter
- #21
What a shame to the designer. If this was a DIY attempt, then I would maybe understand. But, to sell this, with those 10K/W individual heatsinks - this is unbelievable.The small (enclosed) heatsinks couldn't keep-up. The
I have the exact same heatshinks at my mil spec Salas 5VDC PSUAn amp from a renowed brand I bought new a few years back, spec'd 2×120 Wrms / 8Ω and equiped with 2 chunky 340 VA transformers. During summer, the thing shut down twice due to overheating while playing background music in my living room. The small (enclosed) heatsinks couldn't keep-up. The thermal protection sensor (thermistor) on the PCB wasn't even connected to the heatsinks.
So a bit of stress testing can't hurt I believe.
If you insist on using car analogies; if I were looking to buy a car with an engine advertised in the brochure as capable of reaching 10,000 RPM, I would expect it to achieve that without failing.Here we go again with FTC tests in long term max power output...
This is as relevant as testing a car engine running 10.000 RPM for how long until it overheats and breaks: an useless test for an unpractical real use case. Yet the FTC specifies such test for some clueless reason, and even worst, some people insist on it...![]()
I would naturally expect the manufacturer to have implemented the proper measures to ensure it performs as stated in the brochure without any issues.... But some expect to do this hypothetical 10k rpm without a radiator or fan to dissipate heat too.
Bad design. Definitely couldn't sell a car like this!
I think so. If you put a redline on my tach the engine damn well better hang together at that. I would say 5 minutes of that would not be out of line at all. Maybe not all in first gear.How many miles/km do you think an ICE car will last running at redline in 1st gear? Should we standardize the reliability test based on this operating condition?
(e) Any power level from 250 mW to the rated power shall be obtainable at all frequencies within the rated power band of 20 Hz to 20 kHz without exceeding 1.0% of total harmonic distortion plus noise (THD+N) at an impedance of 8 ohms after input signals at said frequencies have been continuously applied at full rated power for not less than five (5) minutes at the amplifier's auxiliary input, or if not provided, at the phono input.
(g) Rated power shall be minimum sine wave continuous average power output, in watts, per channel (if the equipment is designed to amplify two or more channels simultaneously), measured with all associated channels fully driven to rated per channel power.
4.3. 5 minute sine test
The amplifier has not passed the 5 minute test at 2 x 250W/4ohm/1kHz. It was fine first 4 minutes, but then it shut down. Started with THD = 0.11% and reached THD = 0.5% before the shut down. The heatsink fins were slightly warmer at the end of the test period, but some hot air could be detected from the vent slots of the cover plate. After the shut down, the amplifier has recovered in a few minutes.
I would not recommend higher supply voltage for the A07 than 36Vdc.
Some of us feel the need of honest specifications of amplifier output power according to acknowledged documents like FTC regulations and IEC standards. The reason is to get comparable data, protect potential customers and draw attention to false claims of some manufacturers.
I agree in general.I agree with the need for honest measurements. I'm glad for the new FTC rules, and definitely appreciate your time and effort in testing.
But I also think that in all fairness to some of these amps, if their ratings were created prior to the FTC rules that the reports should state that very clearly. In other words, you're expecting them to pass a test that they never claimed they would pass. As a consumer I appreciate knowing that the amp doesn't meet the expectations implied by the FTC, but it's unfair to the engineers who created these products to say they are failing when they never claimed that they would pass.
* )First, this is a general thread, not specific to one manufacturer.I admit to being confused , this thread was about testing to the new FTC rule yet it appears to me that stress testing to 5 minutes at MAX power while perfectly fine to do if you wish is not what the FTC rule says. What am I misunderstanding here?
The 5 minute test should be done at rated power which is continuous average power which is clearly stated on the NC252MP data sheet as 50 watts not 250W / 4 ohm that is Max output.
It would be nice if everyone would get in the same boat as it makes it hard for those of us who aren't as savvy.Conservatively rated at 2x200W continuous into 8 ohms and 2x380W into 4 ohms,
NP. And yes, I had it in mind due from some other research, not really a great example though I do wonder if it meets the revised rule. There are tons of amps using Hypex (etc.) modules that do not spec them properly, but I was too lazy to go deeper in the Duck Duck Go search to copy and paste. Not really relevant; what matters is having and meeting a defined spec.Thanks for explaining. I know the thread isn't specific to one manufacturer but the NC252MP was easy to find and was one tested. It looks like you're using the Nad M23 and where it doesn't say continuous in the specs they do in the literature. ¯\_(ツ)_/¯
That's what the FTC is trying to do. A lot of us were quite annoyed when they "dumbed down" the spec many years ago to bow to the AVR manufacturers; this is a very welcome revision for "old-school" folk and anybody who values reliability and output power defined per spec and not marketing.It would be nice if everyone would get in the same boat as it makes it hard for those of us who aren't as savvy.
