WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
You have a few options with Audirvana. You can use it on your computer wirelessly to the Denon or you could connect a DAC to the Denon and connect the computer to it and control it via Audirvana.
Then, if you want a remote control for the computer running Audirvana you can download the Audirvana phone or tablet app and control the computer playback remotely. However, the app will not work if it can't connect to a computer running Audirvana.
Thanks for explaining that. Would not be a problem to keep laptop running, I just would want it in another room. When you connect to the AVR, is there video displayed on the TV what you are streaming from Audirvana?
That works. As long as the computer running Audirvana (My MacBook Pro) is on and the Audirvana app (on my iPad) are connected to the same wifi or wired network AND you have selected the Denon 3700 in Audirvana using the speaker button (at the right bottom of screen) then the music will stream to the Denon. Your computer can be anywhere in the house. The music streaming will show up on the TV attached to the Denon and the phone/tablet offers the ability to select different songs, search Qobuz/Tidal and control volume on the Denon.
The beauty of this is no compression is done to the source with this process. It's delivered to the Denon in the same format as it's stored on the disk or streamed from Qobuz/Tidal. This allows those HiRes Audio files from HD Tracks to stay High Res and not be downsampled (like Airplay does it).
No, with Audirvana I use the UPnP/DLNA option which is supported by the Denon 3700. With UPnP Audirvana sends the audio to your Denon in the same format it's stored on your computer. It's a great feature!
The computer running Audirvana is doing all the work but the Tablet or phone can optionally be used to control the computer remotely. If no one knows this is how it works - then it would appear to the layman that the phone is streaming the music. No need for HEOS with this setup.
The other nice thing is Audirvana also controls Qobuz and Tidal - so I never use their apps anymore. All my audio is in one single app and available with a single interface. That's awesome!
There's a Music Server app in the USB section that connects wirelessly to my laptop's music files but not clue how to get it to use Audirvana but would the stream be "clean" from the laptop to the Onkyo via wifi? I'm playing flac files and they sound good but I can't stream Qobuz so that's why I was excited for a minute.
