$20k for what is a PC without a DAC or storage!
https://www.stereophile.com/content/pink-faun-216x-music-streamer
Why does one need all this to decode a digital file ?
The Pink Faun arrives in a substantial wooden crate that cradles the streamer in several inches of dense plastic; the weight of the crate and the other packing materials nearly equals the weight of the streamer. It took help and planning to lift it to the top of my rack. As my reward, I removed the top plate to satisfy my curiosity about why a streamer would need to be so massive to accomplish a straightforward, narrowly defined task.
What I saw was a computer motherboard with its CPU liquid-cooled by copper tubes coupling it to the large heatsinks that form the right side of the chassis. The symmetric heatsinks on the left serve to dissipate the heat from at least five large power transistors, part of the multiple power supplies in the Pink Faun. Both of those heatsinks are mounted to chassis side panels more than a half-inch thick. Behind the front panel, mounted to a similarly thick transverse subpanel, are three massive toroidal power transformers that would not be out of place in 250W power amps. There are separate linear supplies for the processor, motherboard, SSDs, clocks, and digital output cards, reflecting the designer's obsessive concern for supplying each of the computer's multiple functional components with an independent, low-noise power source.
