Phono: ADC-->DAC?
dmilller
The Vinyl Wars thread got me curious. Is it common to put digital in the phono pathway to EQ, or are most vinyl users purists and stay analog?
LTig
Europe
I think the majority ofvinyl users still do RIAA EQ in analog since digital solutions are quite rare (Parks Audio Puffin coming to mind). However anyone using room EQ or digital tone controls must use AD/DA. And there is nothing wrong with doing so.
D
dmilller
I've been eyeing the analog in on the miniDSP SHD. That connection would allow me to go balanced from a preamp by the turntable 20 feet away.
I'm sure the RCA connection out from the turntable needs to be short. But I lost that knowledge several decades ago.
Godataloss
Northern Ohio
I'm using the minidsp SHD with a turntable. I've used the balanced out and single ended input with a turntable with great results. The ad/da conversion is inaudible to me. The improvements to be had with PEQ are dramatically audible. It's totally dispelled any mystique of maintaining an analog chain.
LTig
Europe
This is correct. With MC systems longer cables might pickup hum, with MM systems the cable capacitance gets too high which changes frequency response away from flat.
Timcognito
NorCal
great question. great answers. great thread. :)
D
dmilller
I'm assuming the SHD can't take phono level input. Is that correct? Do you develop a PEQ for vinyl?
fpitas
Northern Virginia, USA
I doubt the SHD input is that sensitive. You need one of the phono preamps like Amir has tested, with RIAA and a bunch of gain to get to line level.
Count Arthur
Also, consider that since the 90s most music has been recorded, mixed and mastered digitally, prior to being converted back to analogue to create a vinyl copy.
So, with the exception of early recordings and some speciallity all analogue studios, most recordings on vinyl have already been digitised at some point and you are in effect using your analogue turntable to listen to someone elses DAC. :)
fpitas
Sure, but the warm vinyl smooths over all those digital steps :)
LTig
Europe
A linear preamplifier with again of 20 dB for MM and about 40 dB for low output MC would suffice to digitize the signal and then apply digital RIAA correction. A cheap mixing console might do this; high Z input for MM, microphone input for MM.
Salt
DE
@thegeton gives the answer at post #11.
For low output MC use a transformer may be helpful.
Timcognito
NorCal
Is there a phono preamp that outputs in WiFi? With all the WiFi enabled speakers there should be one.
Salt
DE
If there would be something like this it should have streaming competence to control the speakers?
If not a phono preamp with ADC and USB output could broadcast via WLAN USB Dongle, maybe.
Timcognito
NorCal
I think a phono amp and WiiM streamer works?
