phoenixsong
- Joined
- Nov 17, 2018
- Messages
- 876
- Likes
- 685
Hi All,
Wanted to ask if there are any measured performance differences between phantom power supplies as none of them post any useful specifications, except for the ART Phantom I. Posted this under audio interfaces as I couldn't find anything more suitable, and they can be used together (personally I'm finding a way to use my mics with the Cosmos ADC). Prices can be under $20 or $150+, so if there are no differences it is clear which to go for
Some of the ones from the big brand names:
There are many other Chinese ones available at even lower prices than the Behringer. An example would be Neewer.
StageBug SB-48 - Radial Engineering
The Radial SB-48 is a phantom power generator that creates a stable 48 volt supply for active direct boxes and condenser microphones.
www.radialeng.com
Marantz Professional - Phantom Pack
Marantz Professional Phantom Pack Phantom Power Supply 48V
www.marantzpro.com
M48 | Phantom Power Supply | MACKIE
Order The M48 Phantom Power Supply for a power source you can rely on during any performance. This power source is no nonsense and offers the full power you need.
mackie.com
Phantom II Pro – Dual Ch. Phantom Power Supply – ART Pro Audio
artproaudio.com
Phantom II – Two Channel 12V/48 Phantom Power – ART Pro Audio
artproaudio.com
Phantom I – 48V Phantom Power Supply – ART Pro Audio
artproaudio.com
Behringer | Not Found
www.behringer.com
