Hi all, I'm just getting to grips with REW and have a question about exporting EQ.
I have a simple 2 channel set-up (2-way bookshelf mini-monitors), but in a difficult space. I'll be using a new-to-me MiniSPD to do the correcting. I've done some measurements in REW and (as expected), I'm getting 'different enough' measurements across left and right channels that I want to correct them individually. So far so good. So in REW > EQ panel to create the separate EQ configs for left and right outputs, when I click on "Calculate target level from response" to generate... the target level, I am getting a slightly different calculation for each.
My question is, should I be using these slightly different calculations to base the calculations on, or should I pick a number and use the same for both channels? Or something else?!
Many thanks in advance.
