Evaluation and test of the SMSL D6S
The SMSL D6S being available locally with next day delivery and for a price equivalent to 189US dollar, I have purchased one. I could have bought another Topping E70 which is in the same category and gives me total satisfaction but the E70 doesn’t keep its input selection when power cycled and is more expensive. In another setup I have the SMSL SU1 but it has no XLR outputs.
Here are my first impressions and measurements.
The unit looks quite well build and strong, it doesn’t heat at all.
The manual is minimum, one must play with the knob to understand it’s operation.
While in operation the device display shows only the input sampling rate, the display is mainly useful when you change the settings.
The volume from 99 to 0 is not in dB. But between 99 and 30 each time you decrease by 10 digits you decrease the output by exactly 5dB, or if you prefer 1 digit is 0.5dB.
The unit keeps all it’s settings and input selection while power cycled allowing unattended operation or hidden location.
I have made a few measurements for my own information and fun waiting
@amirm to do a more extensive and accurate evaluation.
I am just using a E1DA cosmos class B as ADC +smsl isolator. The E1DA is just marginally better than the unit. Thus, actual figure should be slightly better. (1 or 2 dB better Sinad max). Software used is RMAA and REW. For RMAA the E1DA is used in stereo mode, for REW it is used in mono mode Left side.
Unsurprisingly all the results are excellent.
Sinad is 120dB for XLR output
Sinad is 118dB for RCA output
Intermodulation IMD din is -110dB
Swept intermodulation function of level
Multitone gives more than 21 bits free of distortion.
And here is a summary of RMAA results
Frequency response (from 40 Hz to 15 kHz), dB | +0.03, -0.01 | Excellent |
Noise level, dB (A) | -123.1 | Excellent |
Dynamic range, dB (A) | 122.8 | Excellent |
THD, % | 0.00005 | Excellent |
Stereo crosstalk, dB | -120.5 | Excellent |
IMD at 10 kHz, % | 0.00027 | Excellent |
As a conclusion the SMSL D6S is an excellent and inexpensive DAC with XLR outputs. Once again professional measuring tools would have given better results but the above results are significantly good enough for my satisfaction.
I regret that almost no DAC has a Bluetooth remote such as the Wiim Pro remote. All those low techs infrared remote really are coming from another century.
Now I am looking for a new amplifier to replace my 25 years old 100w/8Ohms 86dB sinad amplifier. The best that I have found locally is the topping pa7 which I also owns with total satisfaction, but I like to have each setup different.
