New Purifi amplifiers coming
Insane.
The question is why would you need to upgrade? Do you lack power? Or can somehow be the first human ever who can hear distortion difference between 110dB and 120dB?
I’ve done the maths and it’s 10 better. Major upgrade until someone comes out with one that is 11+ better. Like 10 Minute Abs when 9 Minute Abs came out. One better!
Purifi just casually turning into gold anything they touch
Yes. We should just keep in mind that gain is unknown.
Correct me if I'm wrong, but higher gain would rise the noise floor which is essentially the downward slope in the beginning. Even if we raise it to reach the level of the others, still the line goes on and on to impossibly low levels and still shoots high power more than the others. Still insane. :)
Agree
Oh, that's much higher than what I had in mind.
I provoked Claus Neegard a bit when I mentioned that the LA90 had a noise floor of about 2uV and the response was that if one considers it properly it is better even than the Benchmark and the LA90.
I defined it “ludicrously low, not that I have any doubt, I believe it. But it does defy belief” and he admitted that, yes, it was ludicrous (in a positive way).
The buffer board is no longer a part of the whole board that can be snapped off. It is a separate tiny board now.
I may have remembered completely wrong. I asked one year ago, I forgot to ask again this year. Maybe it is a puny 9db. Who knows.
One hopes they can reproduce the low distortion performance in a module with less power.
For those who have active systems you don't need this kind of power for tweeters and midranges.
Yes but it only makes sense if the BOM gets significantly lower. Let us see.
The one and only advantage of the 7040 over the 1ET400A is the power in very difficult loads. All the other metrics are equal or not as good. The 9040 is better than the 1ET400A for all the metrics (at the exception of price).
Not to speak of the fact that it is a radically different design.
They use mathematical models. Just as mathematics has made all old horns obsolete (feel free to use a Goto or a Conic, but then you are a distortion loving dinosaur), they are tackling everything else.
Following a private request, I gathered the (preliminary?) THD+N data from the image provided by @mocenigo earlier in the thread and updated my plot data. The resulting comparison looks like this:
The usual caveats apply: The data is collected from different sources. The amps are using different gains which I did not track. Some are just not specified, some may be listed in the sources below.
Sources:
I would be quite happy with an NCx500!
