New Purifi amplifiers coming
mocenigo
At the High End I met Purifi, and I was offered a sneak peek of the new 1ET9040BA. Available soon-ish, this amplifier module is a full bridge topology (a first for Bruno Putzeys?) and it has a residual noise of 8uV, so it beats the newest NCorex's. As for power and stability, if I understood correctly load impedance is not a problem as long as the amp does not have to deliver more than 90V (180 actually, it is from -90 to +90) or 40A of current. The top is reached at 2 ohm, a "conservative" 1500W. If these numbers for power and stability are correct we have a game changer. A buffer and connectors are on board, but you can "snap" that off. It will be available on their shop as soon as they can get the parts, as you know currently component supplies are vey very tight.
Did he mention any specific integrators already on deck for delivery?
Will they have their own SMPS or will we need to use a Hypex unit, and which one? Thinking this could be a match made in heaven for speakers like the Kef Reference 1 Meta, March Audio Sointuva, and Ascend Sierra LX's which push out l.t. 85 db with 2.83 Vrms.
Nope. Of course this type of information is highly confidential, but I know of at least one integrator that went there, not sure whether this one will use these particular products. He also came to my home to listen to my system and he seemed to be impressed by my speakers.
That one can use the Hypex 2K power supply. They are working on their own, I knew this for some time, but they are not yet ready. They want to do something special.
Should be just about enough power (and more importantly, voltage) for my Soundlabs. As long as it doesn't mind a 1 ohm impedance around 20 khz.
Of course the eternal question......at what cost..........for the amps?
Well it won’t be able to deliver more than 400w, probably a bit less.
No pricing information, but looking at how many components, double that of a 1ET400A would be fair.
Dreamers gonna dream :p
Well the voltage is what helps on ESL's. The Soundlabs have an impedance above 12 ohms and rising in the lower frequencies where most of the power of music is. Being able to swing that much voltage will give it more power there, but not be a big current strain on the amp.
I may sound a bit dense, but I'd rather ask. I have seen two Purifi modules on amps. One offers a bit more power and a bit less SINAD while the other is the opposite.
What does this new one change in terms of performance to those two?
Even more power, and better SINAD at the same time. Also, the 1ET7040SA won’t be available for DIY (at least, this is not currently planned) whereas the 1ET9040BA will be
The naming scheme seems to be
1 = number of channels, in this case 1 (edited)
ET = EigenTakt
70/90 = volts
40 = ampere
S/B = single ended / bridged
A = amplifier module
Previously it was just 1ET + power at 4Ω + A(mplifier)
Roberto
I was thinking about ordering an Apollon multichannel behemoth. Turns out it may be a good idea to wait a little bit. :)
Thanks Mocenigo!
Thanks Mocenigo!
I do not think there will be sound differences and the new modules will be way more expensive. So you should purchase it when you need it. And Apollon does proper assembling! Unless you really need the 40A current the 1ET400A is the better buy.
1ET = first version of EigenTakt typology
I think it's more likely the "1" there indicates number of channels. But we shall see. At least the mysterious "S" in 1ET7040SA has now been unmasked.
Kim Madsen just informed me privately that it is indeed the number of channels .
Roberto
I was thinking about paring those precise modules with an Anthem AVM 90, so the bottleneck should be the AVM itself, not the amp.
Thanks for the heads up!
"The sourcing situation is still bad" wrote Lars today, so it is going to take a while...
